1 Vibration Problem - K75RT Sat Apr 07, 2012 8:06 pm
MLR
Hi everyone.
I'm posting this problem under the 'Engine and transmision' forum because I'm guessing the problem must have its source somewhere there, but I honestly don't know.
For quite a few years now I’ve experienced a bad vibration in the right rear footpeg of my ‘91 K75RT . It appears in the 3000 RPM range and the 5000 RPM range, regardless of the bike being on the centre stand or on the road. This is the only place where the vibration is experienced. The vibration can be felt very slightly at the front end of the footrest mounting plate and it increases the further aft you go, becoming very bad at the footpeg.
It didn’t arrive insidiously over time. It was just suddenly there one day. I could ignore it as it doesn’t affect me as the rider, but it’s so bad that my wife’s right foot goes numb if I’m in those RPM bands long enough, and as we all know an unhappy wife is not a good thing!
The first thing I checked for was a possible crack in the footrest mounting plate and possible cracks in the frame. Nothing. I’ve had the fuel injector sync checked. It was Ok. Changed the rubber shocks in the alternator, loosened off and re-torqued the engine mounts (added a shim at the bellhousing mount) to ensure I wasn’t capturing a stress point in the frame. I’ve had the clutch apart while greasing splines to see if somehow the various components had been assembled out of balance (they are 120 degrees apart). The clutch friction plate shows absolutely no sign of wear, as do any of the other clutch components. In desperation I’ve even run it (on the centre stand) with the rear shock (Progressive) disconnected (sounds weird I know), and also made a brace for the rear footpeg mounting plate in the hopes of dampening the vibration. I’ve even tried wrapping padding around the footpeg, but it doesn't help. The last place I’ve looked (just last week) was under the timing chain cover, thinking that maybe the vibe was somehow coming from wear in there. Sounds desperate doesn’t it!
In short, I haven’t uncovered anything on the bike that could be the culprit. The engine runs smoothly and has plenty of power and is a joy to ride, except for this one problem. The nearest dealer told me that he could try to find the source but, given what I’ve already done he said it could be a very expensive proposition with no guarantee of success.
At the end of my tether. Any suggestions anyone?
1991 K75RT (since new)
Past bikes: Triumph Bonneville 650, Triumph Bonneville 750, Triumph Trident 750, Moto Guzzi T4 850, BMW K75C
