1Back to top Go down   K100 RT Empty K100 RT Thu Jul 08, 2010 8:07 pm
pikeface999
I have just been given the above bike. (poor condiction and fairing removed). Before spending any money I want to see it run. I have cranked it over and have concluded the fuel pump is not running when starter pressed. Could any one please tell me if I can conect power to the pump from the 4 wire tank connecter just to see if the pump runs, if so what color wires to +ve and ne-.
2Back to top Go down   K100 RT Empty Re: K100 RT Thu Jul 08, 2010 11:33 pm
phil_mars
Hi and welcome.
I would be inclined to remove the pump from the tank, quite an easy job, and find out what nasties are lurking in there.
Gives you a chance to check the filter and test the pump externally.
Phil
3Back to top Go down   K100 RT Empty Re: K100 RT Fri Jul 09, 2010 8:54 am
As we don't know if your bike is an early K or a later one, it's a bit difficult to help you.
On the early K100, the color of the wires is brown and green-white. The under tank electrical connector is known to have some problems.
It would have been easy for you to find the color of the wires here
If the bike has not been used for years, I agree with Phil. You should drain the tank, clean it, replace the fuel filter and check if the pump is manually free to turn. Then you should try to power it. The pump is cool down by the fuel. Just try it once outside the tank.
If it's working, reassemble everything and start to troubleshoot the electrical.
K100 RT Frog15K100 RT Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   K100 RT Empty Re: K100 RT Fri Jul 09, 2010 1:44 pm
pikeface999
Thnaks both. I will post my findings when I have removed the pump.
5Back to top Go down   K100 RT Empty Re: K100 RT Sat Jul 10, 2010 5:34 am
pikeface999
Have removed pump and the black rubber around the pump is like jelly, so I guess some will have got in the pump. If there is no other suggestion I will open the pump(saw an artical somewhere) and clear it out.
6Back to top Go down   K100 RT Empty Re: K100 RT Sat Jul 10, 2010 8:52 am
This was expected. The tank has certainly be filled with gas containing ethanol.
Here are the steps to open the fuel pump
7Back to top Go down   K100 RT Empty Re: K100 RT Sat Jul 10, 2010 2:12 pm
ReneZ
ReneZ
get the pump out and submerged in a bucket, change the contacts around, this should make the pump run in reverse. Place filter in correct direction and let the pump run for a while and see in it cleans.
Rene
BMW K100 - 1985 (0030029) Scotland K100 RT Rain
8Back to top Go down   K100 RT Empty Re: K100 RT Sun Jul 11, 2010 4:22 am
pikeface999
THe pump was completely seized up. I have stripped and rebuilt the pump. The pump now runs when I touch the starter button, however fuel sprays from around the edges of the pump.
Not letting that put me of I held the starter button in and low and behold the engine sprang into life. I bit of white smoke but thats probably ok.
So whats to do and is it worth it ?
Put all the fairing back togeter (if the bits are all there)
New Fuel pump
Repair or new water pump (the original problem was over heating, the impellar nut was broken)
new front oil seals
complete new seat
If this is done then I will have a tattry K100 , any thoughts welcolme
Thanks for all the help so far
9Back to top Go down   K100 RT Empty Re: K100 RT Sun Jul 11, 2010 7:17 am
Simple answer to "If this is done then I will have a tattry K100 , any thoughts welcome"...turn it into a rat bike!
Paint everything black. Never wash it again. No-one's going to steal it!
That's what I'd do if I had a "not so perfect" K100 as a second bike.
10Back to top Go down   K100 RT Empty Re: K100 RT Sun Jul 11, 2010 4:04 pm
Rob Roy Mcgregor
If the bike was free you must get it running and use it ,even for the sake of cheap motoring , if not why dont you pass it on to someone else who would benifit from having cheap transport . . K100 RT Icon_cool
11Back to top Go down   K100 RT Empty Re: K100 RT Tue Jul 13, 2010 5:51 pm
Comberjohn
Comberjohn
Had the same problem with my fuel pump and the rubber surround. Blocked the filter but pump was ok. All the parts you mention would be easily available on ebay without spending too much. I would do what blakey suggests and put it back on the road.
12Back to top Go down   K100 RT Empty Re: K100 RT Wed Jul 14, 2010 5:19 pm
pikeface999
O.K, I have now fixed the fuel pump, so I decided to run the engine for a while to make sure it was ok.
Bad new,a lot of steam in the exhaust, so I guess the means a head gasket problem at best.
Time to give up.
Shame
13Back to top Go down   K100 RT Empty Re: K100 RT Wed Jul 14, 2010 5:45 pm
Rob Roy Mcgregor
not time to give up . . get the spanners out and start learning K100 RT Icon_biggrin
14Back to top Go down   K100 RT Empty Re: K100 RT Wed Jul 14, 2010 6:14 pm
pikeface999
time to get the money out and buy one that works
15Back to top Go down   K100 RT Empty Re: K100 RT Wed Jul 14, 2010 6:23 pm
Wrap it up in bubble wrap, stick on some stamps and post it to me!
In my opinion, I would give it a good go to try and get it up and running.
You've fixed the fuel pump. That's a step forward.
Do a compression test. That's step two.
Take it from there to see what's next.
Don't let another one of these fine bikes slip into oblivion!
16Back to top Go down   K100 RT Empty Re: K100 RT Wed Jul 14, 2010 7:15 pm
Rob Roy Mcgregor
spend the money on your bike and get it going instead of spending it on something that will have issues of its own . . also if you fix your own one it will be the devil you know . . your probably 80% of the way getting it roaded allready.motobins gaskit and seal kit £65+vat + your labour costs
