1Back to top Go down   Engine cover bush replacement Empty Engine cover bush replacement Sat Nov 18, 2017 12:19 am
FreyZI
FreyZI
Hola.
Engine back together and looking forward to starting Alda up.  However, before I do that, I thought I'd replace the rubber bushes on the bolts that attach the engine side covers.  There are 22 of them.  The old bushes are not easy to get over the shoulders.  Other than K-Y, any tricks that make this process easier?
Thanks,
Frey
Edit:  Never mind.  I'm just going to tear them off with pliers.  No reason to keep them intact.
Last edited by FreyZI on Sat Nov 18, 2017 12:29 am; edited 1 time in total (Reason for editing : dumb question)
2Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Sat Nov 18, 2017 2:24 am
yep that's the way ...or cut through them with a good set of sidecutters   they do go hard and almost impossible to get over the shoulders
good luck
3Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Sat Nov 18, 2017 3:03 am
You could try soaking in ATF fluid, might soften them. A few guys have suggested it's use to recover old seals.
4Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Sun Nov 19, 2017 8:20 am
KiwiK100
KiwiK100
Why are you wanting to remove and replace them? Are they leaking? If so, give them a good old fashioned boil up. Add a small amount of regular detergent to a pot of water and simmer for 20 to 30 minutes to restore to original shape and softness. If they still leak oil, remove from screw and install a stainless washer behind them. This has the effect of increasing the pressure fit of the rubber grommet to the cover.
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
5Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Sun Nov 19, 2017 11:12 am
KiwiK100 wrote:This has the effect of increasing the pressure fit of the rubber grommet to the cover.
The only problem with that is that you also increase the pressure on the threads in the camcaps. They're marginal as it is.
6Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Sun Nov 19, 2017 12:12 pm
aye ...indeed
the seal around the engine cases proper is probably also gone hard ...
remember wiping leaking stuff off till I changed both ...worth it for a neat and clean bike
were not talking triumphs of the 70s now , are we ? ( shudder )
7Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Sun Nov 19, 2017 10:39 pm
charlie99 wrote:were not talking triumphs of the 70s now , are we ? ( shudder )
Oi! I've got a '62 TR6 in the garage at the moment and it's hardly dripped at all in the last six weeks it's been here. Yes, it does have a full oil tank!
8Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Sun Nov 19, 2017 11:00 pm
Dry sump? ..........................
9Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Mon Nov 20, 2017 5:27 am
just wondering who would be first to bite , and you win Dai ...giggles
thankfully since then there have been some major developments in sealant , remember that black goo ...god awfull stuff
cheers mate
10Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Wed Nov 22, 2017 7:25 am
KiwiK100
KiwiK100
Quite right Dai, but we're only talking a few Nm, 7 or 8 from memory, and hardly enough to cause any stress. I have done this recently on my K1 as I has persistent leaks and it sorted the problem nicely. Or was it the cook up of the rubbers? Dunno as I did both options at there same time.
Current rides:
The family history:
11Back to top Go down   Engine cover bush replacement Empty Re: Engine cover bush replacement Wed Nov 22, 2017 12:13 pm
Someone did it on LFB and split No1 exhaust cam cap. There's a couple of threads left (and I mean two); the OEM bolts won't go in because they have a threadless lead on them. I cut a stainless M6 allen bolt to the correct length and fitted a new rubber. The end of the bolt was given a dose of Loctite and the underside of the rubber was treated to some Threebond. The bolt was wound in until I could just feel it start to tighten, then all was left to go off. Thirty thousand miles later, still no problems.
The biggest 'what-if' nightmare was finding the remains of the cam cap threads in the bottom of the cam cover.
