1Back to top Go down   RS Mirror/Indicator Pod Delete Empty RS Mirror/Indicator Pod Delete Tue Oct 31, 2017 3:48 am
floyd
floyd
At the request of a fellow inmate, here is a very simple and inexpensive way of replacing your missing or damaged RS mirror and indicator pods.
NOTE: This exact example will only work if you have higher handle bars fitted. In this case, I use RT/LT bars. If you use mirrors like these ones on the RS bars you will hit the fairing. Other options would include using a generic fairing mounted mirror or even a combined fairing mounted mirror/indicator unit like on many modern bikes. Bar end mirrors may also work...?
RS Mirror/Indicator Pod Delete K100_211
Search eBay etc for something like "flush mount motorcycle indicators". There are a few styles to choose from, but these triangle ones fit the fairing and style better than any alternatives I reckon. Plus they are mega cheap. I think Ive gotten a set of 4 for $5 delivered from China before...They are bright and visible enough in use too.
RS Mirror/Indicator Pod Delete P1010424
The clear lens is poor quality and breaks easily if struck hard by something like the ground. The indicators will still work though. I bought a set of 2, broke them and then ordered a set of 4 so I have spares...
I also suspect the lenses are not UV stabilized and will perish in a few years of Aussie sun. I have an older one on one side of the bike and it is slightly yellower than the other....
RS Mirror/Indicator Pod Delete P1010422
Inside the fairing....Here ive just pilfered a perfect rubber wire cover/grommet from a stock set of Yamaha XT indicators...(Im using XT indicators on the rear also, but thats another story....)
RS Mirror/Indicator Pod Delete P1010420
RS Mirror/Indicator Pod Delete P1010425
This is a little plastic piece I filled down to sit in between the 'fins' on the inside of the fairing and allow me to fix the indicator on nice and tight.
RS Mirror/Indicator Pod Delete P1010426
Ive used a few sets of this style mirror on a few bikes and love them. Search for 'folding motorcycle mirror' or something similar....about AUD $25 delivered...
RS Mirror/Indicator Pod Delete P1010423
Generic 22mmx10mm mirror clamps - about AUD $2 on ebay....
RS Mirror/Indicator Pod Delete P1010421
2Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Tue Oct 31, 2017 9:54 am
Very nice.  You will be a hero to all of the RS owners who have missing lenses and mirror glass.
looks like a pretty easy retrofit.  One question: did you have to do any body work to the fairing as far as filling holes, etc. to make the signals fit to the surface?  It's obvious you did a repaint.
3Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Tue Oct 31, 2017 11:44 am
rawdonball
rawdonball
Useful post  - thanks Floyd
4Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Wed Nov 01, 2017 4:05 pm
floyd
floyd
Point-Seven-five wrote: One question: did you have to do any body work to the fairing as far as filling holes, etc. to make the signals fit to the surface?
No mate, no modification at all to the fairing. You just remove all the old brackets. Another good feature of these particular indicators is that they cover all the original holes and sit fairly nicely on the fairing surface.
5Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Wed Nov 01, 2017 4:15 pm
RS Mirror/Indicator Pod Delete 112350
6Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Thu Nov 02, 2017 8:24 am
Bigsax
Bigsax
How do you go with vibrations?
The originals shake like a bas***d over about 80.
I have filled my handlebars with lead and now get minimal vibrations on my hands but the mirrors are all over the shop and are only good for seeing headlights at night.
RS Mirror/Indicator Pod Delete Brick110
I stole this image, let me know if you want it back.
7Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Thu Nov 02, 2017 10:15 am
Bigsax wrote:How do you go with vibrations?
You could try tightening the three securing clips by crimping them together slightly or buy new ones from Motorworks.
My R/H mirror was always loose and it fell off for the last time a few weeks ago. I re-glued the two halves back together, tightened the clips and now its solid.
 RS Mirror/Indicator Pod Delete Austra12    Fuel:  95 Octane
8Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Thu Nov 02, 2017 10:55 am
Bigsax
Bigsax
Thanks Holister, I will give it a go.
But I am quite taken with the flush indicator idea.
Most of the mods I have done have involved removing stuff, cutting things down and lowering the rear.
I have flush rear indicators.
Floyd, I also have swapped the RS bars for RT so I guess I am no longer getting the wind protection for my hands from the original mirrors. It looks like you have added hand guards.
Mate can you post a pic head on please.
9Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Wed Nov 08, 2017 12:27 am
floyd
floyd
RS Mirror/Indicator Pod Delete Img_2015
RS Mirror/Indicator Pod Delete Img_2014
10Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Wed Nov 08, 2017 2:11 am
Bigsax
Bigsax
Thanks Floyd!
I have seen some bar mounted mirrors with the indicators integrated into them on Ebay. I have forgotten how to host an image otherwise I would put a picture up.
I am going to give them a go. I have been riding for about a week with a spare bar mirror installed I found in the shed and it vibrates no worse than the original fairing ones.
I will try and work out how to put up some pics when the job is underway.
11Back to top Go down   RS Mirror/Indicator Pod Delete Empty Re: RS Mirror/Indicator Pod Delete Wed Nov 08, 2017 2:13 am
floyd
floyd
By the way, in answer to your earlier Question....Ive never had any issues whatsoever with vibrations...
