1Back to top Go down   Installing a voltmeter Empty Installing a voltmeter Tue Oct 24, 2017 6:29 am
coopz
coopz
Hi All, can someone suggest a good connection for a voltmeter thought about headlight etc but would that give a reduced reading, thanks in advance.
1985 K100 RS
2Back to top Go down   Installing a voltmeter Empty Re: Installing a voltmeter Tue Oct 24, 2017 6:51 am
Take a look at this thread.
3Back to top Go down   Installing a voltmeter Empty Re: Installing a voltmeter Tue Oct 24, 2017 8:19 am
BobT
BobT
It would not give a reduced reading at all. The voltage is pretty much the same all over the system.
I would suggest plus from side lamp bulb as that is easy to get to and negative to earth.
Use a cheap ebay digital one from China, they work just fine.
4Back to top Go down   Installing a voltmeter Empty Re: Installing a voltmeter Tue Oct 24, 2017 9:27 am
Generally, Australian ones from 1985 don't have always-on parking lights (side lamps in British speak). The meter would only work when the lights are on.
One of the other suggestions from the thread Laitch referenced would be needed in this case. BobT's comment is, of course, valid for later and/or other places.
5Back to top Go down   Installing a voltmeter Empty Re: Installing a voltmeter Tue Oct 24, 2017 11:18 am
Chocolate
Chocolate
Hello!
Wouldn’t a easy solution be the best ?
I use it in my car and it works perfect.
Installing a voltmeter 1f0d6410
Installing a voltmeter 9497a210
Installing a voltmeter F6560c10
6Back to top Go down   Installing a voltmeter Empty Re: Installing a voltmeter Tue Oct 24, 2017 12:13 pm
BobT
BobT
Chocolate wrote:Hello!
I have ones very similar to the top one but it is hard wired in.
No Euro model bikes have permanent lights on from that era either. Just thought that as most people ride with lights on it was an easy way to do it. The OP was talking about wiring it to the dip beam so I assume that he rides with lights on anyway.
