1 Seat Refurb Sat Sep 02, 2017 1:53 am
To much mucking around in the end i reckon Martin, which is most unfortunate indeed. Anyways, on with the next plan! Ill get this beast back on these SE QLD roads again one day Im sure!MartinW wrote:Floyd I've never had a good look at the early seat mount set up on the Brick. Does yours have the plate with the mounting bolt? If so would it be possible to pack the front mounts out and slot or redrill the rear mounting plate? This might move your tank back enough to fix or partially fix your problem. You also might be able to crib the ducktail and seat mounts forward.
Point-Seven-five wrote:Not to hijack this thread, but where did you get those turn signals? With the discontinuance of glass and turn lenses for the RS, there are many who would be interested in how you made them work on your bike.
Similar topics
