Number of posts : 7967
sarcastic pig wrote:Ok I'm not sure people are even reading the pist now before answering...
I can't change the master cylinder as the front brakes now operate with the back from a foot pedal...
I am throwing miney at it but can't get a different bike as the thing is actually a trike...
The left callipers is leaking so i need to at least need to find a place in the UK that sell the seal kit...
Not meaning to cause offence with this next bit but please read all the post before putting in uninformed irrelevant replies...
Well I read the post and you mentioned the front brakes. The standard set up is the 13mm front master cylinder for the front brakes. Obviously something has been changed as the footbrake does not normally operate the front brake on any of the Ks. That would be 'linked' brakes and Ks don't have that set up. I don't see that mentioned in your post but then my mental telepathic skills tend to be clouded early in the morning. Some might say all the time.
As regards the brake caliper [and master cylinder] parts I think most of us do actually use the BMW parts BUT the single pot calipers are Brembo and the exact same calipers are also found on the BMW R bikes and Moto Guzzi as well. I have done the brakes on both the K100LT [ABS] and the K100RT [non ABS] and all the parts were BMW. Calipers got new seals, pistons, master cylinders got repair kits and new pistons all with huge improvement.
You did ask about getting an improvement on the original set up, changing calipers is an expensive option due to needing to change the front end which is why you were offered the alternative of a change in master cylinder.
Some have changed the master cylinder unit to do this.
1971 Yamaha 125 YAS-1
