1 Bleeding Brakes the other way Wed Nov 03, 2010 7:25 am
Ajays
I bought a cheap plastic oil can, the trigger variety, and half filled it with Dot4 Hyd fliud.
I spent most of the day trying to expel the air from my Honda front brake and left slamming the door to think about it.
I have never had problems in all my years that weren't cured by leaving it overnight.
No joy next morning, so, with air wanting to get to the top, why not fill from the bottom.
The tube on my bleed screw I pushed onto the oil can and cracked open the banjo at the top next to the brake cylinder. I squeezed the trigger until it leaked at the top then locked the bleed screw tight.
I then pulled the brake lever to expel the last bit of air and finally tightened the banjo. Bingo. Perfect.
This method can be applied to our K's. Put plenty of rag around the banjo so as not to damage the paintwork.
My method in future.
Ajays.
Ajays.
