1 1985 K100 Cutting out when hot - what next? Sat Oct 07, 2017 4:00 am
timz10000
I formerly posted at this link but thought I'd start a new thread for clarity
My 85 K100 starts running rough after about 10 minutes. I'm wondering what to try next - any suggestions welcome!
Symptoms: It starts and runs pretty well when cold. After say 10 mins it doesn't cut out completely, but starts to sputter and run really rough. The battery light comes on at times when it's about to die. I can still rev it high and it seems to run better at high rev (but still not great)
When I cut the motor and leave it for not too long (guessing 10 minutes) it'll start up fine again.
I have a parts bike so I can try swapping things (parts bike hasn't run in many years, but was out of the weather - tank not functional tho)
What it's not:
swapped coils
swapped ECU
swapped ignition control unit
fuel lines replaced inside and outside tank
fuel system has pressure / fuel pump working
thermostat in radiator replaced (failed hot water test so I got a working one)
thermostat temp. sensor replaced
What it might be:
I replaced the Hall Sensors themselves but didn't replace the wiring
When tank is low on gas and I open it, vapor comes out - possible vapor lock? (When I open cap I don't get whooshing of air)
Other guesses:
could fuel pressure regulator or vacuum hoses cause this?
What it's not:
swapped coils
swapped ECU
What it might be:
Other guesses:
1985 K100
