1Back to top Go down   AGM battery capacity Empty AGM battery capacity Tue Aug 22, 2017 2:56 pm
nino
Hi, I have a problem with AGM battery 12 v/35 ah, 2 years old. From time to time in the morning usualy it wont start the engine. Its spinning too slowly. But always start on bump start and fill the battery regularly.
What is confusing is voltage which is 12,9 volts or even 13 all the time. On idle with headlights on voltage is more than 13 volts. Voltage regulator brand new.
Anybody with similar experience with AGM battery?
2Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Tue Aug 22, 2017 4:13 pm
BobT
BobT
It won't be the battery. Probably the battery connectors or starter brushes.
3Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Tue Aug 22, 2017 4:49 pm
Probably starter brushes, do the headlight and or indicators act funky. If they do it is one of the signs of dirty starter brushes.
4Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Tue Aug 22, 2017 5:19 pm
nino
Headlight, indicators, all electrics function normally. I ll try to clean the starter.
5Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Tue Aug 22, 2017 6:40 pm
Clean all your ground connections as well.
6Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Tue Aug 22, 2017 11:48 pm
Yes. Ground connection for sure. Probably the most important one for the starter is the bed where it bolts down to the gearbox with 2 bolts. It can get corroded under there and this is required by the starter for earthing.
 AGM battery capacity Austra12    Fuel:  95 Octane
7Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Wed Aug 23, 2017 1:36 pm
nino
It was most stupid reason - loose minus pole on battery. Thanks all
8Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Wed Aug 23, 2017 1:53 pm
The best possible fix!  One that doesn't require any expense beyond a little time. cheers
Chuckinator
Chuckinator
Am I to understand that I can lay my AGM battery on it's side? This is a big deal as it will positively impact my battery relocation.
10Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Fri Sep 29, 2017 12:04 am
Vitamin K wrote:Am I to understand that I can lay my AGM battery on it's side?
That remains to be seen. Smile
http://www.yuasabatteries.com/faqs.php?action=1&id=27
11Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Fri Sep 29, 2017 7:43 am
If you are constrained for a battery mounting location you might want to use a lithium battery.  They offer a large capacity in a small, light package that can be mounted in any orientation.
If this is a cafe conversion you need it for, I would guess that it would be fairly easy to recoup the additional cost for the lithium based on it's cool factor.
12Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Fri Sep 29, 2017 8:09 am
BobT
BobT
The answer is yes, and AGM or gel battery, as they are also known, can be used on its side.
13Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Fri Sep 29, 2017 12:40 pm
It even states so on the paperwork that comes with the battery. The only no-no is to mount it upside-down - but why would you want to do that!
14Back to top Go down   AGM battery capacity Empty Re: AGM battery capacity Sat Sep 30, 2017 12:36 pm
Chuckinator
Chuckinator
Dai wrote:It even states so on the paperwork that comes with the battery. The only no-no is to mount it upside-down - but why would you want to do that!
Thanks all. This AGM I have is considerably smalller than a standard battery. If I lay it on it's side I can put it in the seat cowl, but I want to keep that space clear for my tool roll and tire plugs, so I going to lay it sideways in the current battery tray and make a clean black box to cover it.
