1Back to top Go down   Two piece fork springs Empty Two piece fork springs Mon Nov 19, 2018 10:53 am
audibob
audibob
Hi all,
does anyone know the origins of the two piece springs fitted to my bike.
I have progressive units on order from motorworks.
BobTwo piece fork springs 20181116
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
2Back to top Go down   Two piece fork springs Empty Re: Two piece fork springs Mon Nov 19, 2018 10:58 am
pretty standard stuff
lots of reasons for 2 springs instead of one
good luck with the new stuff . fitting similar soon on the project bike .
3Back to top Go down   Two piece fork springs Empty Two piece fork springs Mon Nov 19, 2018 11:11 am
audibob
audibob
Thanks Charlie
I looked on the OEM catalogue but could only see single piece springs .
Cannot wait to try the new springs, getting very fed up with excessive front end diving....
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
4Back to top Go down   Two piece fork springs Empty Re: Two piece fork springs Mon Nov 19, 2018 12:15 pm
audibob wrote:I looked on the OEM catalogue but could only see single piece springs .
The early RS models had sport forks with similar assemblies. This diagram is from the MAX BMW fiche.
Two piece fork springs Screen33
5Back to top Go down   Two piece fork springs Empty Re: Two piece fork springs Mon Nov 19, 2018 2:12 pm
'S' forks or sport forks were a dealer-installed option for K100 and other K75 from about '87 onward, marked by an S stamped and visible on the top plug in the end of the fork tube. They came as standard equipment on the K75S after a two years of production. I fit them to my '87 RS and they are quite firm.
These springs are not particularly effective in non-'S' forks. Notice in the provided photo how a suitably long piece of PVC was used for preload, because they are far too short to do any good. They likely would not produce excessive dive. I would research just what brand forks are on this bike and re-fill them with the prescribed viscosity and level of fork oil. Too little can produce a sloppy action. Too much can be harsh. Look at the inside of each fork leg for marks indicating a brand, like F&S, etc.
6Back to top Go down   Two piece fork springs Empty Re: Two piece fork springs Tue Nov 20, 2018 2:09 am
A picture is worth many (don't know about a thousand) words.
Here is the OEM spacer & spring arrangement from "S" forks that TWB spoke of in his post. From my K75.
Two piece fork springs Image22k
7Back to top Go down   Two piece fork springs Empty Two piece fork springs Tue Nov 20, 2018 5:27 am
audibob
audibob
I cannot see any "S" markings, and they are brembo forks.Two piece fork springs 20181119
My two piece spring set differs from the set in your foto Gaz.
Just as luck would have it, I found one dust cover cracked when I wiped off the crap, ah well time for new seals
and covers...
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
8Back to top Go down   Two piece fork springs Empty Two piece fork springs Tue Nov 20, 2018 5:52 am
audibob
audibob
Sorry for the double post.
I googled the numbers on my forks, and they are from the k100RS
The guide ring, part number 31421450517 seems a loose fit on the piston is this normal ?
This is my first time I have done fork springs etc, so I want to get it right first time.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
9Back to top Go down   Two piece fork springs Empty Re: Two piece fork springs Tue Nov 20, 2018 7:27 am
This is where you find the "S" on the so called sport forks.
Two piece fork springs S_fork11
10Back to top Go down   Two piece fork springs Empty Two piece fork springs Tue Nov 20, 2018 8:30 am
audibob
audibob
No "S" marking on my forks Gaz..
There must have been a reason to someone when they fitted the sports springs.
They are not going back in, so they will go in my spares bin, just in case I ever decide to
buy a bag of bits.....
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
11Back to top Go down   Two piece fork springs Empty Two piece fork springs Wed Nov 21, 2018 2:10 pm
audibob
audibob
I am finding it difficult to compress the new springs enough to fit the circlip.
My current springs sit a lot lower in the leg with retainers fitted and the spacer in situ,  making the circlip  very
easy to fit.
My current springs and spacer measure 51cm with the spring retainers fitted.
The new progressive springs measure 53.3 , without the retainers fitted,
so with them fitted , they sit  a lot higher , making it almost impossible
to fit the circlip
OEM part number 31421450539 shows the K100 lt spring retainers, which look
thinner at the base than mine .
Has anyone fitted progressive springs from motorworks and used the original
retainers, and still found it easy to compress the spring and fit the circlip ?
The only place I can find the retainers are on ebay in germany
bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
12Back to top Go down   Two piece fork springs Empty Two piece fork springs Wed Nov 21, 2018 2:32 pm
audibob
audibob
Doh...
If I had looked harder, I would have found the retainers  on motorworks.
Hope I can get that circlip in now.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
13Back to top Go down   Two piece fork springs Empty Two piece fork springs Thu Nov 29, 2018 5:08 am
audibob
audibob
What a difference to how the bike handles with new springs  ( progressive from Motorworks ).
As per previous posts about fitting them  I did not use the retainers .
I also found out why she used to wander sometimes when leaning around a left hand bend.
The left fork had very little oil in it,  the right fork was okay.
No obvious signs of a leak...  perhaps I forget to refill it after changing the seals ....
Doh...
Admittedly I have not serviced the forks for three years,  lesson learnt.
The firmer action under braking is nicer, I will fit a tie wrap on the legs, and measure the fork travel.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
