1Back to top Go down   K1100 side cover  Empty K1100 side cover Thu Sep 28, 2017 12:05 am
K1100 side cover  716d0710K1100 side cover  716d0710Hello Ladies and gents;
I have just acquired some side covers for my K1100LT and unfortunately 2 of the mounting bits ( the circular standoff thing that goes into a grommet on the frame and the "U" shaped device  that also connects to a rod on the frame are not only broken but not included.
So if anyone has a busted sidecover ( assume K100 16V similar ) that still has the 2 attachment bits I need I would love to do business with you :O).
Will try to send picture soon.
regards KKlompy
KKlompy K1100 side cover  2854237993
K1100 side cover  Au-log10
2Back to top Go down   K1100 side cover  Empty Re: K1100 side cover Thu Sep 28, 2017 2:40 am
Those things are like hens teeth. I had a cover here that had a steel clip made from box strapping and epoxied to the inside of it.
Don't be too concerned about them falling off as both mine have been broken since I got the bike and both are still with me.
3Back to top Go down   K1100 side cover  Empty Re: K1100 side cover Thu Sep 28, 2017 5:35 am
RicK G wrote: I had a cover here that had a steel clip made from box strapping and epoxied to the inside of it.
Snap.
Oops... maybe the wrong expression? Very Happy Very Happy Very Happy
4Back to top Go down   K1100 side cover  Empty Re: K1100 side cover Thu Sep 28, 2017 5:41 am
Thats a bugger Klompy .
These are what I found on the back of Smurfettes sidecovers . I''m not sure if the LT is the same .
As Rick mentioned maybe some replicating with a metal clip may do the job .
Ol Blue had some metal clips fashioned up by a PO , and worked  quite well.
Just a thought , pop into Bunnings plumbing section . Find some hard plastic tubing or alloy tubing you can split open , and use to adhere to the existing clamp.
Good luck with it .
K1100 side cover  Img_7916
K1100 side cover  Img_7917
K1100 side cover  10_x_110
5Back to top Go down   K1100 side cover  Empty Re: K1100 side cover Thu Sep 28, 2017 6:58 am
how bout a broom holder clip from Bunnings .....for one of em anyhow
6Back to top Go down   K1100 side cover  Empty Re: K1100 side cover Thu Sep 28, 2017 3:07 pm
That's what's inside both of the LT sidepanels I have.
7Back to top Go down   K1100 side cover  Empty Re: K1100 side cover Fri Sep 29, 2017 2:42 am
Here's an example of a K1100RS panel that I fixed.
K1100 side cover  11rs_side_cover_repair
8Back to top Go down   K1100 side cover  Empty Re: K1100 side cover Fri Sep 29, 2017 3:39 am
Garyk100
Garyk100
Same as my k1100lt  homemade clips made from hard plastic tubing zip ties and araldite, but they still fall off, I will fashion something similar to the ones mentioned on here, a good post at the right time, don't have a pic, although should put one up to show how not to do it
The early bird catches the worm, but the second mouse gets the cheese
1991 K100rs16v
9Back to top Go down   K1100 side cover  Empty Re: K1100 side cover Fri Sep 29, 2017 6:20 am
Thanks guys looks like an ugly but functional device or 2 is in order....lets see the frankenbike with rivets ties and hot glue residue. Cheers KKlompy
10Back to top Go down   K1100 side cover  Empty Re: K1100 side cover Fri Sep 29, 2017 8:28 am
Just to make you feel like part of the team Klompy, I'm with Rick G, my K1100LT sidecovers have broken clips the same as yours and have been like that for many thousands of kilometres.
I'll watch your fix.
