1 Fuel level lights Wed Sep 20, 2017 1:55 am
timo27
Hi all, 1984/85 k100, I understand the difference between the early models fuel senders up to a point - but could anyone confirm the following info works around the use of potentiometers
Early K-bike Fuel Light Fix
By Jim Solberg
September 2002
K-Tech Page Maintainer's Note: This will only work for early K-series bikes. Certainly those with the amber 7l light and the red 4l light, later ones up to the point where the analog sender was installed.
Purchase two 1 K OHM potentiometers from Radio Shack, #271-342, for $1.49 each. Splice one into the brown/white (4 liter) wire and the other one into the brown/black (7 liter) wire, where the wires go into the tank.
Measure 4 liters of fuel into an empty tank. Adjust the potentiometer for the red light so it comes on at the 4 liter content in the tank.
Obviously, the other potentiometer should be set so that the yellow light comes on at the 7 liter level. Of course, you could be creative and set them to come on at any level you desire.
Rather than empty the tank, I emptied almost all of it, then ran the bike until it ran out of gas, so I would have a true indication of liters remaining of useable capacity.
You can get as fancy or simple as you want with the installation. I mounted the pots in a small plastic box, with the adjustment screws accessible through two small holes drilled in the box. I also mounted a small switch through the box and wired it to be able to disconnect everything from the fuel lights just in case the fix didn't work. I spliced in enough wire to be able to mount the box to a frame member just behind the right side cover. I filled the box with silicone, completely covering the pots and switch, as protection from the elements and vibration.
This fix has worked flawlessly for sixteen years.
By Jim Solberg
September 2002
