1Back to top Go down   Fuel injector reinstalling Empty Fuel injector reinstalling Mon Sep 04, 2017 9:01 am
renriv
renriv
have had the injectors out on a K100RT - after much grunting and cursing !- but they don't seem to be going in far enough when i put them back. If I screw the fuel rail down tight does this seat the injectors properly. It seems to me they are still leaking slightly. Do I then have to adjust the bypass screws separately to get the bike idling smoothly ?
2Back to top Go down   Fuel injector reinstalling Empty Re: Fuel injector reinstalling Mon Sep 04, 2017 9:51 am
Use some Vaseline on the O-rings and put all 4 into the rail, put the clips on then put them into the head. You should feel a very positive seating of them then put the screws in to hold them in place.
3Back to top Go down   Fuel injector reinstalling Empty Re: Fuel injector reinstalling Mon Sep 04, 2017 10:18 am
I just put motor oil on the O-rings.
Install them on the fuel rail first.
Line them up and tap the fuel rail with a rubber mallet to seat them.
If you don't have a rubber mallet handy then use a small block of wood and a hammer.
4Back to top Go down   Fuel injector reinstalling Empty fuel injector reinstalling Tue Sep 05, 2017 12:01 am
renriv
renriv
OK Thanks. That's basically what i've done so i'll try giving the rail another hit !!
