1 Please help! Maybe bad CDI or other?? Tue Sep 05, 2017 5:21 pm
53cr3t5quirr31
Okay so I have a 1987 k100rs I have turned into a cafe racer. The bike has only 30k miles and I am having a load of issues. Went to start the bike today and nothing... I click the starter it does a quick jolt of the starter then cuts out.. immediately I think it's the hall sensor.. nope hall sensor checks out fine... all of my fuses are good.. all connections and electric grease on them.. as I was trying to get it to start the ignition coils started to buzz almost as if they got stuck or something.. I unplug the coils from the harness and bam! The bike constantly turns over but no fuel pump.. strange... I check the pump with a 12v jumper it works I then go to the under tank connection and I am getting 8volts with the starter depressed and it jumps to 10volts for 1.5 seconds after starter is let go... changed out FI relay.. nothing.. cleaned the starter winding and brushes.. nothing... swapped the load shed and light relay and the light still works.. only 8-9volts at number 6 fuse.. their is continuity from the computer to the FI relay but it is always at 0volts and does not carry 12volts with the ignition on.. do i need a new computer?? Anything I'm missing? Sorry for the long post I wanted to be thorough
