1Back to top Go down   91 K100RS Empty 91 K100RS Mon Sep 04, 2017 6:35 pm
Overkill
Overkill
Hello,
My son and I have a 91 K100rs that has been stored for many years. He is getting married soon and as one of my presents to him I have decided to get the bike running in good condition again. I pulled it out of storage to find everything in the gas tank to be junk.
I replaced the fuel pump,filter, lines and sending unit. I then rebuilt the front master cylinder and installed a new battery. It had new tires four years ago when put away inside so those seem fine.The bike starts and runs great. But I have an ABS light that wont go out even at speed.
I purchased a code reader and reset the abs and the motronic unit. The ABS wont reset and was flashing a code 6 (ABS relay) until I tried to reset the ABS and now it flashes a code 7 (ABS computer). I recently had carpel tunnel surgery and as my hand is done for the day I was hoping someone could help tell me common things to look for at this point so I have some idea where to start when my hand recovers again!
Thanks so much for any thought you can give me!
2Back to top Go down   91 K100RS Empty Re: 91 K100RS Mon Sep 04, 2017 8:31 pm
This guy is the guru of the ABS for our bikes. just about every test is up on his site. What Tosi doesn't know isn't worth knowing.
http://bmwk10075abs1fix.web.fc2.com/
3Back to top Go down   91 K100RS Empty Re: 91 K100RS Mon Sep 04, 2017 8:59 pm
Overkill
Overkill
RicK G wrote:This guy is the guru of the ABS for our bikes. just about every test is up on his site. What Tosi doesn't know isn't worth knowing.
 Thank you!
