1Back to top Go down   Cluster removal how to? Empty Cluster removal how to? Wed Aug 30, 2017 1:23 am
SniperX
SniperX
Apologies if this is in the incorrect place! I am going to remove my clusetersoo and need to know if there is a primer or how to of some sort here. I am hopeful there not only is, but there is a wrote up with pics if it;s complicated. Seems easy enough but you know how that is....like when Jeremy Clarkson says "what could possibly go wrong?"
1985 BMW K100RT, 2006 Ducati ST3, 1996 Honda CBR1000f, 2001 Honda XR400r
2Back to top Go down   Cluster removal how to? Empty Re: Cluster removal how to? Wed Aug 30, 2017 1:35 am
Easy peasy. No pictures necessary.
5mm Allen wrench to remove the four bolts in holes from behind.
Then there's a small Phillips crew in the center of the wiring harness connector to remove the plastic cover.  Then pull out each 12 wire side of the connector.
3Back to top Go down   Cluster removal how to? Empty Re: Cluster removal how to? Wed Aug 30, 2017 2:47 am
SniperX
SniperX
duck wrote:Easy peasy. No pictures necessary.
 Thanks Duck! Can I get to everything with the fairing in situ?
Cheers!
Kev
4Back to top Go down   Cluster removal how to? Empty Re: Cluster removal how to? Wed Aug 30, 2017 2:57 am
or
you can  just remove the 2 bolts holding the bracket for the cluster onto the head -triple clamp bracket on the rt types
still need to remove the phillips screw holding the cover of wiring connector
once removed the 4 bolts that duck mentions are soooo easy
and yes no fairing parts need removal
good luck
5Back to top Go down   Cluster removal how to? Empty Re: Cluster removal how to? Wed Aug 30, 2017 2:58 am
Yes, the RT is probably the easiest to do with the fairing on.
If you want a K where it takes work to get the cluster off then I recommend a K75S or K1100LT.
6Back to top Go down   Cluster removal how to? Empty Re: Cluster removal how to? Wed Aug 30, 2017 3:09 am
SniperX
SniperX
duck wrote:Yes, the RT is probably the easiest to do with the fairing on.
LOL! Nope! I'll stick with the RT for now....although a K75S is NOT out of the question!!!! I just rebuilt the cluster on my 1985 Dinan 535i, and it was a right doddle. The K bike is engineered a LOT like my 535i! I am sure it'll look familair when i get in ther as well. The Dinan will be back on the road soon too....just waiting for a new diff mount and some shifter parts.......
7Back to top Go down   Cluster removal how to? Empty Re: Cluster removal how to? Wed Aug 30, 2017 3:13 am
Can be done with fairing on but on my K100RT I found it so much easier when I removed the screen for access, it also gets the black cross member out of the way as the screen bolts keep it in place too. I didn't remove anything else but I did slacken off the two Allen bolts under the ignition pad to allow it to move just a little, don't think that's wholly necessary. I also removed the mounting bracket bolts as suggested by Charlie99 and then removed the cluster from the mounting plate...make it easier!.
Its an easy job!
8Back to top Go down   Cluster removal how to? Empty Re: Cluster removal how to? Wed Aug 30, 2017 12:56 pm
Corkboy
Corkboy
And be very careful in taking out the small philips screw holding in the wiring cover.  It has a habit of falling out and the spiders running away with it.  DAMHIK
Either use a magnetic screwdriver, or have some receptical handy under it when taking it out/putting it in.
             '87 K100RS 0140995 (Gone)
             '97 K1100LT 0188024 (Gone)
             '08 Transalp 700
9Back to top Go down   Cluster removal how to? Empty Re: Cluster removal how to? Wed Aug 30, 2017 5:50 pm
Corkboy wrote:And be very careful in taking out the small philips screw holding in the wiring cover......have some receptical handy under it when taking it out/putting it in.
That or a bucket of swear words!!!
Cluster removal how to? Ir-log1188....May contain nuts!Cluster removal how to? Ir-log11
K75RTP - 1994
10Back to top Go down   Cluster removal how to? Empty Re: Cluster removal how to? Thu Aug 31, 2017 7:31 am
Well I had the screen and cross panel off when I did mine......so it was a case of just pick it up....
