1 Another oil pressure warning lamp question Fri Jul 02, 2010 5:40 am
Kerswellcrank
Hi all, I recently noticed the oil pressure warning lamp isn't coming on with the ignition (before starting the engine).
I pulled the wire off the pressure switch on the oil pump and touched it to earth, the lamp lit ok, so I took the switch off and cleaned it, including the small hole on the oil side.
Put it all back together, turned on ignition....Yaay, red light. Started the bike and the light went out almost immedately....good so far. Turned off the engine, waited a few seconds, switched ignition on....no lamp!
So my question is... Is this normal? should the oil warning lamp come on every time the ignition is switched on, or does the oil pressure stay high enough in the engine for the lamp to stay off even without the engine running?
I should add that the pressure switch is quite new, as I replaced the old leaky one recently. Also I changed the oil and filter about 300 miles ago, and it still looks nice and clean. Lastly, even after parking the bike all day, the light doesn't come on.
Thanks guys.
Steve
Thanks guys.
Steve
