1 i'm amazed!! Sun Jul 30, 2017 7:35 am
k-rider
during these last few months , my k100 2 valve ,have been running more and more ruoghly , and even noisier than it used to , about a week ago i decided that maybe changing the spark plugs , and cleaning the leads and caps would remedy the problem , it didnt .
today i had a little spare time , and decided to do a sync of the TB's, hmm , that didnt help either, then took some flammeable contact cleaner , and sprayed around the injectors , and hey , spraying at #1 and 2 , did make the engine rev a little faster.
mind you these injectors where only installed 3 years ago ,reconditioned 4 pintle spray pattern of course with new o-rings and filters. the o-rings where very spongy , but didnt look cracked, only did about 60000 kms , shouldnt they last longer than that?
well , of with the injector rail , i had some new RED o-rings , so it was a simple swap,clean of the gunk from the cylinder head ,reinstall the rail, and of for a test ride ,
and it is as if i have a new engine , it runs sooo smooth and quiet ,even the gear change seems better , well that last bit might be imagination,
but it truly amazes me that those 2 little rubber things will have such a big effect to the engine
have a nice sunday
k-rider
have a nice sunday
k-rider
k100rs 1983 -o:
Shinny black ,exaust from a 16valve ,engine from a 1990 K100 lt,fd ratio :32/11
