Number of posts : 7963
And you only need the ice pick to remove the radio.
Which is not fitted on the RT models, its on the LT models.
And.....its strongly advised if you have never done it, to replace the fuel lines as they go hard with age and after you put it all back together will likely crack and leak fuel under pressure...put them back about 1 1/2" longer and you can access radiator coolant cap and the electrical relay box without removing the tank.
1971 Yamaha 125 YAS-1
