1 Steering Fri Jun 30, 2017 6:41 am
Bunyak100
Can anyone give advice regarding the removal technique of the stem from the lower fork clamp, my on has moved due to fork damage and is a few degrees off centre, and not square with two fork clamp holes, I have check runout with daily gauge and a square. I would like to remove cleanup, check stem for straightness and reinstall. Is it threaded or an interference fit, there does not appear to be any circlip.
