1Back to top Go down   Valve stem oil seal tool Empty Valve stem oil seal tool Mon Jul 03, 2017 3:43 pm
aladin1
aladin1
I'm in the process of renovating my K100 engine and need the tool to fit new valve stem oil seals ( BMW 11 1 940). I can't find anywhere selling them after Googling for UK suppliers. Can anyone direct me towards a source or an alternative method?
2Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool Mon Jul 03, 2017 8:28 pm
I've always used a socket or a piece of tube of the correct diameter. Just had a look at my Haynes Manual and they show a socket in section 2.18. However AGA tools have a set for $990.00. Valve stem oil seal tool 25650
Regards Martin
3Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool Mon Jul 03, 2017 8:38 pm
I used this tool set to do mine.  When I was done I sold them for $10.  I greased up the valve stem with assembly lube to help the seal slide down the shaft and lube the guide.  Worked a treat.
http://www.ebay.com/itm/Valve-Stem-Seal-Seating-Remover-Tools-Set-Installer-Oil-Plier-Car-Garage-Tool-/122511503658?epid=1354135908&hash=item1c8641312a:g:23QAAOSwuMZZI-Yl
4Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool Mon Jul 03, 2017 9:12 pm
Point-Seven-five wrote:I used this tool set to do mine.  When I was done I sold them for $10.  I greased up the valve stem with assembly lube to help the seal slide down the shaft and lube the guide.  Worked a treat.
That is fairly much what I use except that mine is a lot older and has a pressed metal case that weighs 2 ton Very Happy
5Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool Tue Jul 04, 2017 4:06 am
aladin1
aladin1
Thanks for the advice guys.....I think I'll pass on the $990.00 AGA set Martin and have a look on fleabay for a cheapo set like Point.Seven.Five used, and I'll check out the socket method.Valve stem oil seal tool 112350
6Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool Tue Jul 04, 2017 2:36 pm
mike d
If you are a UK BMW Club member, we have the seal tool in the Tool Hire facility.
Mike
7Back to top Go down   Valve stem oil seal tool Empty Re: Valve stem oil seal tool Tue Jul 04, 2017 6:06 pm
aladin1
aladin1
Thanks Mike......I have managed to fit the seals using a short section of tube. Fingers crossed that all is OK.
