1Back to top Go down   Re-Keying Motocase locks. Empty Re-Keying Motocase locks. Mon Apr 29, 2013 7:17 am
MikeP
MikeP
There are plenty of good "how to" articles out there but as far as I know none show the tang you need to find to release the lock barrel from the clamp.
When I first did a set it took me ages to locate it as the articles (the ones that I've read anyway) tried to describe the location.
I've just done another set and thought I'd get a photo of the tang in place, it may help anyone like me who struggled to find it the first time.
Re-Keying Motocase locks. BMW%20K75S%20%28409%29-L
A good explanation of the process can be found here:
http://www.motobrick.com/index.php/topic,494.0.html
2Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Mon Apr 29, 2013 7:24 am
Well done Mike.
That's a big help.
3Back to top Go down   Re-Keying Motocase locks. Empty Any Tips? Mon Apr 29, 2013 12:18 pm
ibjman
ibjman
Nice pics.
I found the tang on the seat/helmet loop lock kind of challenging to release......can't see it at all in there!
Any special tools for that one?
Oh....BTW....besides the normal clean & lube ideas....is there any way to improve the opening of those latches so the'll really POP over the detent when trying to open them with just one hand. Mine are a little old & stubborn, and it often takes 2 hands to get the latch to pop up. Geeeeeeze I hate that
4Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Mon Apr 29, 2013 12:44 pm
Brickee
Brickee
I sprayed mine w WD-40 and seems to free them up nicely.
86 K100RT VIN 0053533
The good news is, I no longer have senior moments. The bad news is, now it's a constant state of mind.
5Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Mon Apr 29, 2013 1:17 pm
MikeP
MikeP
I'm not keen on WD40 as a lubricant, it doesn't last very long (that's not what it was designed to do). I use white grease in an aerosol can with a tube. It allows me to get the grease where it needs to be on the hinges and slides. Being grease it lasts well.
6Back to top Go down   Re-Keying Motocase locks. Empty No keys at all Wed Jun 14, 2017 8:33 am
Bunyak100
Bunyak100
I just just purchased a 88 K100LT with no keys at all, can I take a compartment lid with lock to locksmith to obtain a ignition key? Or what are my best options.
7Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Wed Jun 14, 2017 8:43 am
Chocolate
Chocolate
Bunyak100 wrote:I just just purchased a 88 K100LT with no keys at all, can I take a compartment lid with lock to locksmith to obtain a ignition key? Or what are my best options.
Hello!
Take the frame number and go to the next BMW dealer and order a new key. That's how we do it here. A copy does any locksmith, if he is good.
8Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Wed Jun 14, 2017 10:54 am
The compartment lids have only 4 tumblers and the ignition lock has 5 so you will need the ignition lock or steering lock.
9Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Wed Jun 14, 2017 10:57 am
I bought a derelict parts K100 all in pieces once.  It sat in my garage for several months and I forgot that I'd duct-taped the key to the frame so that I wouldn't lose it. So when I got around to the fuel tank (having forgotten about the key,) I just took the whole gas tank, with about a gallon of really old gas/water in it, to a locksmith to get the lock picked. Fortunately the guys at the locksmith had a good sense of humor because when they picked the lock to get the gas cap open it stank up their whole shop. affraid
10Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Wed Jun 14, 2017 11:29 am
Chocolate wrote:Take the frame number and go to the next BMW dealer and order a new key. That's how we do it here. A copy does any locksmith, if he is good.
That would work if the ignition switch hasn't been changed in 29 years.  Laughing No guarantees there.
11Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Thu Jun 15, 2017 1:40 am
nvboy
nvboy
MikeP wrote:There are plenty of good "how to" articles out there but as far as I know none show the tang you need to find to release the lock barrel from the clamp.
With minimal ability and a bit of patience I followed this link last year and re-did my pannier locks to work with the new key for the ignition and gas cap I bought.  Worked a charm and now I only have to worry about one key.  I just acquired a 22L top case and will probably attempt the same.
nvboy
Re-Keying Motocase locks. Can-lo10
12Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Thu Jun 15, 2017 1:56 am
The 22L locks can be a little finicky to get the lock core out.  But don't give up as it is possible.
13Back to top Go down   Re-Keying Motocase locks. Empty Lost Key Thu Jun 15, 2017 3:26 am
Bunyak100
Bunyak100
I did check with the Local BMW Dealer and on checking they advised that the key is NLA from supplier in Malaysia using VIN.
Is the Tank key the same as ignition key?  ( ex Factory)
14Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Thu Jun 15, 2017 3:29 am
Bunyak100
Bunyak100
RicK G wrote:The compartment lids have only 4 tumblers and the ignition lock has 5 so you will need the ignition lock or steering lock.
Rick,
Will the fuel tank cap lock be 5 tumblers same a ignition?  Can I remove the fuel cap to take to locksmith?
15Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Thu Jun 15, 2017 3:55 am
Yeah AFAIK it has 5 tumblers
16Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Thu Jun 15, 2017 4:19 am
Chocolate
Chocolate
Hello!
As I said, take the framenumber, go to the BMW dealer, he will do 2-3 clicks on his computer and you will get a new key.
Was 6,29€ for me, than make a copy at the locksmith and put the original somewhere safe.
This will only work if the locks haven't been change.
17Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Thu Jun 15, 2017 10:37 am
Chocolate wrote:Hello!
Here in the US, not all dealers will do this. Don't know if the root cause is stubbornness or ignorance.
18Back to top Go down   Re-Keying Motocase locks. Empty Re: Re-Keying Motocase locks. Thu Jun 15, 2017 1:30 pm
If you want I can ask here about a key as my friend works for the local BMW dealer and they are helpful [at a BMW price of course]. I got things before and all they needed was the 7 digit VIN, first one or 2 digits being zero.
Looks like small money I will happily post over, only takes no more than a week and isn't even price of a beer. If it's big money get another ignition and rekey the other locks.
You can open the gas tank with SidecarPaul's little hole drilled for emergency opening, just put a grommet in it.
