1Back to top Go down   Cooling System Empty Cooling System Sat Jun 10, 2017 5:19 pm
beemernug
beemernug
Can anybody help. I have a 1987 K100RT and need to replace the Thermostat. I have purchased a Thermostat but it did not come with the seating gasket that fits onto the actual Thermostat. BMW do not seem to have this part listed separately. I have the dealership looking into this problem with BMW. I am reluctant to fit the old seating gasket onto the new Thermostat as it is 30 years old and slightly hard. Has anybody had this problem before and does anybody know where I could purchase one. Name and address of company and if possible e-mail address. Any information would be helpful. Thanks!
2Back to top Go down   Cooling System Empty Re: Cooling System Sat Jun 10, 2017 6:16 pm
As far as I can tell, the only seal in the vicinity of the thermostat is an O ring (item 4 on the Real OEM schematic).
Cooling System Thermo10
Available from both the following:
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=GA&SbCt=BA_15_40_GA_70
http://www.james-sherlock.co.uk/shop/k75-k100-k1100-k1200/engine-cooling/radiators-and-parts
Hope this helps.
Cooling System Uk-log10 Cooling System Sco-lo15
                              Paul  Cooling System 905546712
3Back to top Go down   Cooling System Empty Re: Cooling System Sun Jun 11, 2017 10:06 am
That O-ring is to seal the cap. The thermostat gasket goes under the base of the thermostat to ensure proper flow thru the t/stat valve. AFAIK they aren't, and never were, available as a separate item.
- I've always reused the gasket. On my K100naked its busted but I put it back in carefully.
- I'd say you could install the t/stat without the gasket anyway. Might take just a fraction longer to warm up in cold climates.
- Alternatively, get some cork gasket material and cut yourself a new one.
 Cooling System Austra12    Fuel:  95 Octane
4Back to top Go down   Cooling System Empty Cooling System Thermostat Gasket Mon Jun 12, 2017 6:24 am
beemernug
beemernug
Thanks for the info. I have the 'O' Ring. Still waiting for BMW dealership to get back to me. If everything else fails will put the old gasket back on the Thermostat. Will the cork withstand the high temperature if used, concerned it might start to break up?.
5Back to top Go down   Cooling System Empty Cooling System Thermostat Gasket Mon Jun 12, 2017 7:13 am
beemernug
beemernug
I have resolved the issue relating to the Thermostat Gasket. The Thermostat that I ordered from Motorworks did not have a gasket on and it should have as it is part of the Thermostat, the same goes for the BMW Dealership which they were looking into why it did not have one on. Contacted Motorworks and they are sending me a gasket after checking their stock and stating they all have them on apologising also.   So again many thanks for you that replied to my query.
6Back to top Go down   Cooling System Empty Re: Cooling System Mon Jun 12, 2017 9:53 am
Good news. I've heard of others ordering the thermostat from other suppliers and it arriving without the gasket. I've never had to buy one. Just removed it on occasion to test.
7Back to top Go down   Cooling System Empty Re: Cooling System Mon Jun 12, 2017 7:04 pm
Hi beemernug.
This topic has been moved.
The information here (which may help others) would be lost in Member's Introduction. Very Happy
