1 k100 cafe racer running problem Thu May 25, 2017 12:05 pm
tyetye
HELP.....
ive not long finished my cafe racer project but seem to have a problem.. firstly i need to stay ive changed the air intake and it practicly has no exhaust now. looks good and sounds te bollocks but i have a flat spot mid range.
it rides fine at low revs and goes like a missle when i open the throttle but if i try to hold the throttle mid range, its flat , almost feels like a misfire. the throttle bodys have been balanced and the airflow meter has been adjusted to compersat the K&N air filter, valve clearances are ok, new plugs and leads seem to be good. TPS is working and adjusted correctly.
im at a loose end???????
its not stopping me from enjoying the bike but would like to get to the bottem of the problem.
if someone can also tell me how to add pictures to the thred i will.
thanks.
thanks.
