1Back to top Go down   Start issues fuse 5 Empty Start issues fuse 5 Thu Apr 20, 2017 3:50 am
leon83
leon83
Hi there, I'm about to have a minor breakdown. The electrical part is quite intense (my first time). But I'll manage.
I removed the complete cockpit, buttons etc. Replaced it for a custom made cockpit with LED's and switches. The flashing lights, brake light, horn etc are working fine.
But when I turn the ignition key, hand brake, foot brake, clutch in, and then the start button, Fuse #5 blows every time.
I changed the position of the battery, motronic and ignition control unit. So I think I made a cable mistake there.
1. The thick cable tree of the motronic has a loose black cable, that one supposed to go to the mass of the engine right (minus of the battery)?
2. has the Ignition Control Unit some kind of mass cable too?
3. How can I test the Ignition Control Unit?
Any ideas?
http://www.leonvanzanten.nl
2Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Thu Apr 20, 2017 7:20 am
leon83 wrote:But when I turn the ignition key, hand brake, foot brake, clutch in, and then the start button, Fuse #5 blows every time.
If the fuse blows in the same moment you push the start button......
check the wiring between the start button and the starter relay.
Next step disconnect the connector with the two small wires at the starter
relay.....if the fuse still blows, the problem is in the wiring mentioned above
....if the fuse don't blow, the problem is internal in the starter relay.
Above I'm assuming that you don't have connected a lot of other this and
that to the same line the fuse protects.
3Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Thu Apr 20, 2017 5:42 pm
leon83
leon83
did the test, thanks for that. The fuse still blows when I disconnect the plug.
So what does that mean? Can it be the starter (brushes)?
4Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Thu Apr 20, 2017 6:12 pm
kioolt
kioolt
From reading your post it sounds like you have done extensive rewiring of the bike.  The reason that I mention this is that normally the starter itself is not fused, so the starter brushes could not be the problem.  The starter relay however is fused normally I believe.  If this bike wasn't blowing fuses prior to your rewiring I would suspect a problem in your rewiring instead of a bad part.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
5Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Thu Apr 20, 2017 7:04 pm
leon83
leon83
I just cut everything of (no cockpit left). And made a new one, but haven't hooked it up yet. Besides the horn, flashing lights and backlight I'm starting with the start switch. So I don't think that that is a big problem isn't it?
So the only cable which can be wrong is the black cable coming from the ECU (motronic). I'm not sure if that one needs to be connected to the mass.
6Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Fri Apr 21, 2017 12:27 am
leon83 wrote:I just cut everything of (no cockpit left). And made a new one, but haven't hooked it up yet.
Please post a photo of the new loom you have made and how your bike looks at this stage of the project.
7Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Fri Apr 21, 2017 3:12 am
leon83
leon83
Here some photos.
Start issues fuse 5 Img_2611
Start issues fuse 5 Img_2713
Start issues fuse 5 Img_2415
Start issues fuse 5 Img_2511
Start issues fuse 5 Img_2712
8Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Fri Apr 21, 2017 3:39 am
leon83 wrote: The fuse still blows when I disconnect the plug.
Does the fuse blow in the same moment you push the start button?
9Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Fri Apr 21, 2017 3:54 am
leon83
leon83
yes. Right at that moment.
I think the black cable which comes out of the big cable string of the ECU has to be connected somewhere else. But I don't know where.
10Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Fri Apr 21, 2017 4:28 am
I don't think the cable at the ECU have something to do with this problem
as it seems like you have a short between the starter button and starter relay.
Leave the small connector at the starter relay off.
Disconnect the big connector for the RHS switch assy...RHS under the tank.
At the connector on the main harness side bridge a couple of wires on the
side of the connector where the wires enter.
Bridge green to green/yellow. (kill switch)
Bridge black/green to black/yellow. (starter button)
Turn the ignition on, and off again after a couple of seconds.
If the fuse don't blow reconnect the connector at the starter relay to check
if we have connection all the way.
Turn on the ignition for a couple of seconds again, the starter should turn.
If the fuse don't blow the problem is in the RHS switch assy or related wiring
.......or we have to look elsewhere.
11Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Sat Apr 22, 2017 7:35 am
leon83
leon83
SO HAPPY!!!! and a bit ashamed as well.
So I made the new cockpit. Connect all the wire correctly fortunately. I connected all the plus cables together with nice ring sockets. But that bundle was touching my stainless steel cockpit cover. I didn't finished and closed it yet because I'm still working on it. So now put a nice piece of heat shrink over it and problem solved. Thanks everybody. This was a great help.
12Back to top Go down   Start issues fuse 5 Empty Re: Start issues fuse 5 Sat Apr 22, 2017 9:53 am
Start issues fuse 5 112350
