1Back to top Go down   Gasoline smell on exaust Empty Gasoline smell on exaust Mon Apr 10, 2017 6:06 am
nino
Hello,
I tried to reduce idle speed on k 100 8 v by central idle screw but it didnt react as expected. Then I tried with brass inlet screws. First cylinder almost no reaction, second same, third cylinder reacted instantly, fourth like first and second very slowly.
Anyone could explain why only one cylinder reacts? Finally I reduced idle with brass screw on third cylinder. All the time there is intensive gasoline smell on exaust. Could it be leaking injector? Maybe third?
FPR is almost new.
2Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Mon Apr 10, 2017 6:32 am
Nino,
The exhaust on my bike with the sidecar is always very rich and the exhaust always has a black deposit. Hopefully, I will start to work on it by the end of the week. (end of the winter in Canada). I will let you know what I find.
Gasoline smell on exaust Frog15Gasoline smell on exaust Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Mon Apr 10, 2017 6:44 am
nino
Maybe temperature sensor sends signal for richer mix?
4Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Mon Apr 10, 2017 6:56 am
nino wrote:Maybe temperature sensor sends signal for richer mix?
This is exactly what is my suspicion and I have a new one to be installed. This as well as the air flow meter will be my first steps for troubleshooting.
Once the sidecar is re-installed, the space to access the air box and temperature sensor is very limited and this is why both device will be replaced before having the bike on the road.
The snow is almost gone and I am anxious to be riding again.
5Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Mon Apr 10, 2017 7:33 am
nino
Mine MAF doesnt react on bypass screw. Engine runs even with a totaly closed vane, but performs well. Consumption is little bit higher
6Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Mon Apr 10, 2017 11:25 am
There are two things I would do first off Nino.
Check the SPs. If one is wet then its probably that injector leaking but I doubt there'd be enough fuel to smell it out the exhaust. If all are wet then I'd be first looking at the sensor (test pins #10 & #13 on the FICU plug) or try swapping the FICU itself with a known working unit. We've seen a few failures lately and over fueling seems to be a symptom.
Just my thoughts mate. Cheers
 Gasoline smell on exaust Austra12    Fuel:  95 Octane
7Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Mon Apr 10, 2017 8:05 pm
like
8Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Mon Apr 10, 2017 11:28 pm
nino
Thanks Bert and Holister. I have a plus FICU in garage but from swiss bike which was electronicaly  limited to 6 th rpm. Bay the way is there a possibility of removimg FICU blocade
9Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Tue Apr 11, 2017 3:42 am
nino wrote:Thanks Bert and Holister. I have a plus FICU in garage but from swiss bike which was electronicaly  limited to 6 th rpm. Bay the way is there a possibility of removimg FICU blocade
I was wondering if it's the FIcu or the Icu that lock the RPM at 6K max. In my opinion, it was the ignition computer.
I started the ETK and checked both. Very Happy
For the fuel injection unit the only option is "official vehicles" when for the ignition unit, the option is "Switzerland version?"
This leads me to believe that I am right in my assumption that the rev limiter is built in the ignition unit and not the Fuel Injection.
10Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Tue Apr 11, 2017 4:13 am
nino
I am not shure but I think its black box in the head of the frame. I tried swiss bike K 100 and it was limited to 6500 rpm, with red mark on rev counter.
I swapped that black box and suddenly same bike went to usual limit of 8700 rpm freely. So FICU or ICU? What is it
11Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Tue Apr 11, 2017 4:16 am
nino wrote:I am not sure but I think its black box in the head of the frame. I tried swiss bike K 100 and it was limited to 6500 rpm, with red mark on rev counter.
This is the Ignition Control unit (ICU).
What you may want to swap first to solve your problem is the Fuel Injection unit(under the seat/tool box.
12Back to top Go down   Gasoline smell on exaust Empty Re: Gasoline smell on exaust Tue Apr 11, 2017 4:20 am
nino
I have one, will try. in the meantime chaged temp sensor this afternoon. Also used one but I saw some improvement. Not so much smell from exaust any more.
