1Back to top Go down   Plastic Welding Panniers ? Empty Plastic Welding Panniers ? Mon May 25, 2015 5:35 pm
TheJoker
TheJoker
I've noticed after looking over my panniers that one of them has a split in it, it's about 4 inches. Now I'm thinking of saving this said pannier by plastic welding has anyone ever done it before. Or has anyone repaired any of their pannier Question
(Don't really see any point of chucking it).
My Bike List past to present so far;
Lexmoto (first bike ever to ride) , CB125 TDC 86 , CG125 89 , GN125 97 , ER5 96 , K100 RS 84
84/01 K100rs 0013627
2Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Mon May 25, 2015 5:40 pm
When I had Krausers I used to take the brute-force approach to repairs i.e. an ally plate and lots of pop-rivets/small button-head allen bolts. I never trusted plastic welding. I think it was the L/H pannier on my Guzzi G5 that would have given the Terminator a good run in the rivetted ugliness stakes.
3Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Mon May 25, 2015 6:10 pm
Snod Blatter
Snod Blatter
If you might chuck it anyway I guess the real question is "does it melt properly?".
4Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Mon May 25, 2015 8:18 pm
I believe they are made of ABS plastic.  Should be marked somewhere on the inside for recycling purposes.  If so, I would get some thin ABS thermoforming sheet at a plastics supply house and use ABS plumbing cement to bond a piece of the sheet to the back of the crack.  The cement has solvents that will weld the the patch to the case material.  Much stronger than heat welding.
5Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Tue May 26, 2015 6:44 am
WoodyAUK75
WoodyAUK75
I had one pop open on me and wear away the front corner of the lid before I could say" What's that noise?" I fibreglassed it. It's functional, but not perfect. The mechanic next door said to try spray putty or car bog to give it a smooth finish.
6Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Tue May 26, 2015 9:50 am
td5
td5
I had a small crack in the outer shell, and my locksmith (yes really) recommended Loctite 406
It has worked well and I'd recommend it, here is some info on it.
http://www.loctite.com.au/3320_AUE_HTML.htm?nodeid=8802625486849
7Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Wed May 27, 2015 8:20 am
TheJoker
TheJoker
Interesting replies thank you, I've got some loctite somewhere so I'll give that a go first off see if it results in anything good. Otherwise I think I'll try the rivet idea. It's ok at the moment however if the pannier is full I wouldn't really trust it.
8Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Wed May 27, 2015 8:28 am
malcoops
malcoops
fibreglass on the inside, easy and you don't have to be too tidy then once sealed you can spray putty /bog sand up the hairline cracks
Laugh and Laugh Often
bmw kl1100lt, 1993, honda cx500 1978, honda gl500 1982, and bits and pieces
9Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Wed May 27, 2015 9:21 am
If you find a small piece of the same type of plastic you can use acetone to glue them together. Not the fake sort chicks use to remove nail polish but the proper stuff. If the two surfaces don't mate completely you can make a sort of slurry by melting some plastic shavings in acetone and apply to the surfaces. Either way you gotta clamp or hold firmly till set. The less glue you use, the stronger the bond
Drilling and rivets will actually stress and weaken the area. Fibreglass will stick but how long it will last is difficult to say. The problem with both these is that the pannier will flex quite a bit.
Someone further up suggested plumbers glue. I think that would be worth a try. Test a small area first.
 Plastic Welding Panniers ? Austra12    Fuel:  95 Octane
10Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Wed May 27, 2015 11:54 pm
Capt., I suggested the plumber's ABS cement.  The black stuff that has plastic dissolved in it.  I have used it to assemble tweeter arrays for PA speaker systems.  The cement makes a bond stronger than the pieces being joined.  You just have to make sure the stuff you are welding is ABS.  I am pretty sure the panniers are, but it doesn't hurt to check for the ABS recycling symbol.  As I mentioned, applying a patch is the way to go as it will make the repair much stronger.
I would also drill a small hole at the very end on the crack and fill it with cement.  This will help prevent the crack from spreading further.  Sort of a second line of defense.
11Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Sun Jun 07, 2015 4:31 pm
Wigwam
Wigwam
There are many solutions, this is the best one I have found.  PlastiFix, supplied by the Urethane Supply Company.
See their video.  Even though they used white resin in the video, you can order it in black.
https://www.youtube.com/watch?v=j4RECGjEOnE
12Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Tue Jun 06, 2017 10:11 am
Filmcamera
Filmcamera
I have used the method that Delboy uses in this video.  It worked great for me.
Using plastic ties and wire to add material and strength mean I think the repair is the strongest part of the case.  Do it on the inside of the case and if you line it up right the crack should be virtually invisible from the outside
13Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Tue Jun 06, 2017 10:41 am
k-rider
k-rider
i have done this with my panniers ,a very old set ,i just didnt use any extra material like cable ties ,good idea though ,i just melted it from both sides , since i didnt care much about the look of it .
k-rider
14Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Wed Jun 07, 2017 6:51 pm
Mikewills
Mikewills
Unfortunately if they are made of ABS then a cable tie won't do the job as it's a different plastic. It's a straight forward repair by plastic welding using a mini heat gun. ABS welds fantastic and I'd happily do it for anyone that requires
15Back to top Go down   Plastic Welding Panniers ? Empty Re: Plastic Welding Panniers ? Wed Jun 28, 2017 10:40 pm
baja-ru
baja-ru
cheers  I'm glad I stumbled on to this topic. I'm gonna give mine a go and try to repair it the same method. Very Happy
