David Nimrod
David Nimrod
Recommend me some Vacuum Gauges please... Best Vacuum Gauges for a K1100LT (UK Please) ~ 112350
What I'm out for is a good time
All the rest is Propaganda! Best Vacuum Gauges for a K1100LT (UK Please) ~ 112350
mike d
Morgan Carbtune
Mike
Corkboy
Corkboy
Seconded.
But - as they are needed so rarely - only really if you change valves, it would be cheaper to borrow a set if possible.
             '87 K100RS 0140995 (Gone)
             '97 K1100LT 0188024 (Gone)
             '08 Transalp 700
mike d
I administer the UK BMW Club Tool Hire facility. It has a Morgan Carbtune that I hire out to members. The only problem is that sometimes you need to clean the stainless steel rods as they can get a bit sticky'. Have hired them out countless times as the work on carbs and throttle bodies.
Mike
Here's what I use.  Connect to two throttle bodies.  Transmission fluid in bottles flows to bottle connected to the highest vacuum.  Cost $15 and works as good or better than the fancy ones.
Best Vacuum Gauges for a K1100LT (UK Please) ~ Thrott12
David Nimrod
David Nimrod
Thanks for the info... much appreciated Best Vacuum Gauges for a K1100LT (UK Please) ~ 112350
Davida. They'll take a far greater battering than the Morgan and still come back for more. Mine are now around 25 years old.
