1 K100 diesel. Fuel pump problem? Original pump Mon Mar 20, 2017 2:38 pm
touchwoodsden
This is rather an odd one. It concerns the K100 fuel pump.
I have an early K100 which is fitted with a Mercedes Smart Diesel engine.
The original in tank pump circulates the diesel fuel as it did in the bike and feeds the high-pressure injection pump.
It is running at about one bar.
It has done about 800 miles or so with this setup without a problem but recently, after running for just a short period of time (it first manifested itself on a run out) the bike started to slow and eventually cut out.
I discovered that switching the fuel pump on and off (the kill switch does that) it’s okay again for a mile or so and then it starts slowing down.
As the problem seems to resolve after the fuel pump gets a bit of an electrical kick, I am wondering whether there is a problem with the fuel pump. I know it wasn’t meant to run on diesel fuel and nor was the filter (new) and I can always make other arrangements but the reason for posting is to ask if there are any known problems with these pumps. I can’t imagine that diesel would cause problems where petrol will not although of course, the fuel pump is having to work harder because the fuel is thicker.
What is surprising me is that the fuel pressure is not dropping.
The other thing to ask is whether there are different sizes of pump or whether they are all the same.
Thanks for the answers guys.
