1Back to top Go down   K75 RT 1995 computer plug Empty K75 RT 1995 computer plug Tue Mar 28, 2017 11:17 am
Grahame
Grahame
I'm trying to lift the computer out to get at the battery but am unable to remove the plug.
I've raised the seat and removed the side panel and clip on plug cover then removed the tray cover so that I can see hole where you insert the screwdriver to operate the plug catch.
I've followed the instruction manual but with no luck, it just will not release the plug.
Anyone got any ideas?
K75RT ABS Mystic Red 1995 7th owner
Engine No.753EA 0294
Chassis No. 03706294134
Mileage 24/12/18  40,399
2Back to top Go down   K75 RT 1995 computer plug Empty Re: K75 RT 1995 computer plug Tue Mar 28, 2017 12:03 pm
Move it in the opposite direction; it will release if you're pulling the right side of the plug where the cord is attached while you're prying and muttering. Laughing
3Back to top Go down   K75 RT 1995 computer plug Empty Re: K75 RT 1995 computer plug Tue Mar 28, 2017 12:18 pm
I just looked at the diagram in the 1994 Rider's Manual. bounce  Not too helpful but interesting and could keep a person occupied for an afternoon.
The plug latch gets moved rearward. When you do that you'll be able to pull the plug outward from its right side then unhook its left side.
4Back to top Go down   K75 RT 1995 computer plug Empty Computer plug Tue Mar 28, 2017 12:58 pm
Grahame
Grahame
Thanks for the advice, it's done!
I found a picture of the computer on ebay, once I knew how it worked it was easier but required a fairly firm push on the clip to free it off. Have now topped up the battery for the first time in 2 years.
5Back to top Go down   K75 RT 1995 computer plug Empty Re: K75 RT 1995 computer plug Tue Mar 28, 2017 5:20 pm
Messing with the engine control unit and the battery hold down is why I am glad I have no-maintenance AGM batteries in my bricks.  Install and forget about them for 5-6 years.
