1 Spline lube after 45 th km Fri Mar 17, 2017 6:50 pm
nino
After 45 th kms I dissasembled final shaft to grease splines. Last time I did it at 135 th kms, now bike is on 180 th kms. At 135 I used ordinary cheap graphite grease and when opened the final drive grease looked rather fresh. Cleaned everything and put different barium complex grease for nautical use which is probably much more durable
Here are pictures of front and rear end of final drive after cleaning of old graphite grease
I have a question: Is there any possibility to mount back final shaft on some wrong way?Not to push enough?
