Point-Seven-five wrote:Mass Air Flow sensor.
It's in the air box above the filter and tells the engine controller how much air and, by inference, oxygen is coming into the engine for combustion.
How reliable are they? I've got an 85 K100RT that idles and runs good for the most part but it has a unsettling habit of (every now and again) sputtering and stalling when your accelerating off of idle.
And very rarely at speed I'll get a short buck out of the engine
Usually in 1st gear. I did plugs, injector cleaning, wires, fuel filter. I understand the fuel pump was replaced just before I got it. Speedo shows 28K miles and I suspect it doesn't have more than 35K on it.
Cleaned the ignition switch, kill switch is ok.
Tried unhooking the TPS and no change.
replaced the fuel lines.
I thought it was vapor lock but it idles great even when it's really hot.
No indication of an electrical failure when it happens. All gauges stay on , no indicator lights,
I cleaned the tank bottom plug for the fuel pump so I think thats ok also.
I am installing the fuel line heat insulation wrap just to cover that base. But I am annoyed with this problem and want to fix it. Any Ideas?
