1Back to top Go down   Chinese injectors Empty Chinese injectors Fri Mar 10, 2017 5:37 am
nino
Hello, I found few brands "chinese bosch EV 1" fuel injectors with price from 13 do 20 USD for one. All of is labelled as 0280150211 bosch - for k 1100 or K 100 16, which means hogher pressure 43,5 intead of 36 psi plus little bit higher output.
Did anyone tried k 1100 injectors on k 100 8 V?
2Back to top Go down   Chinese injectors Empty Re: Chinese injectors Fri Mar 10, 2017 6:02 am
Chocolate
Chocolate
Hello!
Read this: 1 hole Vs 4 hole injectors
The 0280150211 should be fine for the K 8V bike.
But you should know what you receive from China.
I use the 415 injectors in both K 75 8V
Chinese injectors Img_2810
3Back to top Go down   Chinese injectors Empty Re: Chinese injectors Fri Mar 10, 2017 6:13 am
nino
What is MEPEH? Some injectors company. Do you have any link?
4Back to top Go down   Chinese injectors Empty Re: Chinese injectors Fri Mar 10, 2017 6:45 am
Chocolate
Chocolate
Hey Nino!
This picture is copied from the thread Link I have posted above.
I don't know the company.
5Back to top Go down   Chinese injectors Empty Re: Chinese injectors Sat Mar 11, 2017 4:47 am
nino
Hi, when compare 210, or 211 with 415 on K 75 which do you like more? Do you use ordinary bike setup pressure regulator with 415injectors?
6Back to top Go down   Chinese injectors Empty Re: Chinese injectors Sat Mar 11, 2017 5:05 am
Chocolate
Chocolate
Hello!
The 210 are the original, they are old and have to be cleaned or replaced. The 210 injector are ONE hole injector and the spray pattern is very basic.
The 415 are a good replacement, FOUR hole injector with a much batter spray pattern and the amount of gasoline sprayed is a bit larger. This will result in a smal amount of more power.
Besides that the O-Rings etc. should be renewed if you get the 415 injectors. The bike setup will stay the same, no change needed!
