1Back to top Go down   odometer Empty odometer Sun Nov 20, 2016 3:55 am
wicky
wicky
I noticed a few rides ago that my odometer was not working. I still had speed and rev just no odometer. Just fro a few notes I have seen it may be a stripped gear?
The bike is an 88 model with 12000km it is in good condition but has been sitting a long time, there was a corroded Shocked hole in the tank.
any suggestions would be welcomed before I attempt to dismantle the gauges.
2Back to top Go down   odometer Empty Re: odometer Sun Nov 20, 2016 4:12 am
I haven't had to replace gears, but have dismantled gauges from casing. Happy to help if wanted. Very Happy
3Back to top Go down   odometer Empty Re: odometer Sun Nov 20, 2016 4:26 am
The gears are quite easy to replace. If it is the stubby small gear that has died, you can get it as part of a package with other gears for about $9 from Jaycar. Otherwise they can cost about $25 each plus postage.Usually if one gear has gone the others are not too far behind.
4Back to top Go down   odometer Empty Re: odometer Mon Nov 21, 2016 1:37 am
Do a search of the Forum...there's lots of posts and lots of photos too.
5Back to top Go down   odometer Empty Theres your problem Thu Jan 26, 2017 4:08 am
wicky
wicky
Thanks for the info I was hoping for a simple problem. I pulled the speedo/tacho unit off and disassembled, the gears in the odometer were striped ainsjac you said the gears could be bourt from jaycar can you give me more info on that? what should I be asking for? what does it go in?
Regards
6Back to top Go down   odometer Empty Re: odometer Thu Jan 26, 2017 4:34 am
Look for Gear Set....yg-2630. Take your smallest gear with only one set of teeth on it and there is a replacement in that set. The rest of the gears in the packet are of no use. It is just cheaper for that one gear and the rest you will need to get elsewhere. Good luck. There are references to places to buy them on the forum, just type in Speedo gears or odo gears.
7Back to top Go down   odometer Empty Re: odometer Thu Jan 26, 2017 8:25 am
nino
I bought set from hardtoptire - Spain. All gears 25,5 Euro without post expences. Very good service
http://www.hardtoptire.com/familia-hardtop.php?id_familia=104&id_catalogo=19
8Back to top Go down   odometer Empty Re: odometer Thu Jan 26, 2017 1:56 pm
great find nino ..!!!
thanks for the link
9Back to top Go down   odometer Empty Re: odometer Fri Jan 27, 2017 4:15 am
"I bought set from hardtoptire - Spain. All gears 25,5 Euro without post expences. Very good service"
Hey nino, I've sent you a PM.
