1 K100 get rid of the air mass sensor and use K1200 configuration instead??? Wed Apr 05, 2017 12:59 am
Atsea
Hi
I have a K100 which I'm converting into a cafe racer. I want the bike to be as lean as possible and the air box on top of the throttle body and air mass sensor box are huge. The k1200 has nothing but air filter directly on top of the throttle body so I was thinking if I could use the K1200 ECU instead of the K100 and avoid using the air mass sensor and all the plastic boxes on the engine. It is possible doing something like that?.
Has anybody make a conversion of this type?. I'm using a m-unit motogadget so I will remove the relay box already to simplify the electrical system.
Thank you in advance.
Atsea
Atsea
