1Back to top Go down   K1100 fork seal's need changing Empty K1100 fork seal's need changing Sun Dec 11, 2016 9:29 am
DeRodster
DeRodster
All righty then,
and first up   Happy Christmas santa   rendeer to all
So, to fit NEW fork stanchion's + seals
I think I have all the bit's req'd (I think)
I've seen the horror on Youtube (that guy in the USA) of seized fork yoke bolts, so fingers crossed I won't have to suffer that !!!
But also the Youtube K seal + oil change...seems straightforward enough
Anything I need to be wary / aware of ( ps I have done it in the past...just not recently
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   K1100 fork seal's need changing Empty Re: K1100 fork seal's need changing Sun Dec 11, 2016 9:43 am
Motorbike Mike
Motorbike Mike
I had to take the forks out of my K11LT for seal replacement and whole procedure is straight forward. The only issue I had was getting the ABS sensor out of the left leg. I can't remember why I wanted it out but it was SOLID! Give all the internals a good clean before reassembly as they'll be coated in nasty dark grey oil.
I put 15w oil in when I refilled them which made my front end steer better without excessive dive under heavy braking. Having lived with 15w oil for 12+ months it's occasionally a little harsh but worth it if you ride with some enthusiasm.
Good luck.
3Back to top Go down   K1100 fork seal's need changing Empty Re: K1100 fork seal's need changing Sun Dec 11, 2016 9:55 am
DeRodster
DeRodster
Good man Mike,
All noted
No doubt I will have a bit of cleaning off to do
but hopefully it won't be too bad
all the best
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
4Back to top Go down   K1100 fork seal's need changing Empty Re: K1100 fork seal's need changing Mon Dec 12, 2016 4:25 am
O both my Ks the stanchions refused to come out.....it became necessary to remove the entire assembly as one and take it to machine shop to have it all pulled apart.
5Back to top Go down   K1100 fork seal's need changing Empty Re: K1100 fork seal's need changing Mon Dec 12, 2016 6:21 am
BobT
BobT
Mine came apart quite easily. I too had a problem getting the ABS sensor out.
I put 10w oil in mine, but then bought some 7.5 oil for the next change, which I haven't done yet.
Olaf couldn't get his out because of his small stature, he has problems lifting up spanners that are bigger than a 13mm.  Smile Smile Smile Smile Smile
6Back to top Go down   K1100 fork seal's need changing Empty Re: K1100 fork seal's need changing Mon Dec 12, 2016 6:57 am
BobT wrote:Mine came apart quite easily. I too had a problem getting the ABS sensor out.
Really?????
K1100 fork seal's need changing Olafs_11
7Back to top Go down   K1100 fork seal's need changing Empty Re: K1100 fork seal's need changing Thu Dec 15, 2016 5:52 am
Hi Rod, I bought these. Good quality and price, p&p etc.
Just be careful to take the opportunity to clean all the old oil and crud out of the fork ( most of it seems to come from the bronze bushings. ) .  For refilling I found it easiest to put the fork upside down in a vice and fill through the drain hole with a syringe from your local friendly Pharmacy/Vet etc. etc.
Finally lube the lip of the seal with some fork oil, silicone etc. and be very careful getting the bronze bushings back in past them. Can't remember if I used the tooth floss trick on this set but think I did.
Feel free to shout me on the mobile if you need a hand.
K1100 fork seal's need changing Ir-log1188....May contain nuts!K1100 fork seal's need changing Ir-log11
K75RTP - 1994
