3 Re: Flooding Fri Mar 19, 2021 2:46 pm
Number of posts : 4216
Check the engine temperature sensor. Should be about 2500 ohms at room temperature dropping to about 250 ohms at normal operating temperature.
Another check would be if there is a short to ground in the injector wiring harness. Injectors work by having 12v at all times on one terminal, while the ECU pulses the ground connection to open them. If the harness is shorted, it's possible to have the injectors open all the time. Turn on the ignition and with a voltmeter check the voltage across the terminals in an injector plug. Should be 0 volts. If you get 12v it means that the injectors are being turned on.
