1 Help--bike starts and dies--already changed Hall Sensor, Fuel Pump, Filter and Cleaned Computer Connections Mon Aug 01, 2016 6:17 pm
jumpinjimmy
Any advice?
Go to page : 1, 2
jumpinjimmy wrote:hah, 1985 k100RS Sorry!
jumpinjimmy wrote:I don't think it's a pump or filter issue as both of these components are new and I can clearly hear the pump turn if I bump the starter button. Where is the four pin connector you mention? Inside the tank?
Where were you measuring and what pressure were you getting?jumpinjimmy wrote:......I've already done the fuel pressure test which is what made me decide to change the pump (outside the fact that it was an original part and very noisy). There was too much pressure which indicated the relief valve was not working properly.
1989 K100RT VIN 0097367 (naked) 1996 K1100RS VIN 0451808 | Fuel: 95 Octane Engine Oil: Nulon Full Synthetic 15W50 Gear Box Oil: Nulon Synthetic 75W90 |
Holister wrote: Check the fuel return hose at the front/left under the tank. It comes from the FPR. Disconnect it and stick in a 2 litre coke bottle.
For clarity, are you referring to the test on the last page or the second last?jumpinjimmy wrote:I used the test outlined in this PDF for testing the pump and according to this article it was the relief valve in the pump that was bad.
http://tomwade.me/motorcycles/technical/k100troubleshooting.pdf
It would've been useful to know what pressure you got with this test. It may have explained a kinked fuel line in the tank.jumpinjimmy wrote:I used the test outlined in this PDF for testing the pump and according to this article it was the relief valve in the pump that was bad.
Its not a hard road to venture down. Very easy to do.jumpinjimmy wrote:Thanks for the responses. Never backfires and it always!! starts right up...even now with this problem. Check valve clearances?? I'm afraid you'll have to explain the reasoning before I venture down that road.
Go to page : 1, 2
K100-forum.com » Technical, repair and troubleshooting » Electrical » Help--bike starts and dies--already changed Hall Sensor, Fuel Pump, Filter and Cleaned Computer Connections
Similar topics
