1Back to top Go down   One for the peeps in Oz...multimeter Empty One for the peeps in Oz...multimeter Mon Nov 07, 2016 8:52 pm
FYI..
Here is a good cheap multimeter for sale at Jaycar for $14.95AU with a continuity buzzer!
Good little meter that but seeing as I already have a multitude of multi-meters I think I will skip it.
Probably even fit in the glove box of an LT
blaKey wrote:FYI..
Good value!
A consideration: I've found some of the cheaper ones are a bit slow to respond. e.g. check for continuity, expecting zero resistance but it takes 3 or 4 seconds to settle on the figure. Likewise battery voltage takes a few seconds to stabilise, usually rising to the final value over several seconds.
Better meters will be much quicker, but cost a lot more. As always, cost for performance. Depends on your needs.
"Depends on your needs"
It sits nicely in the rear cowl of my K.
