1Back to top Go down   Engine noise on cold (again) Empty Engine noise on cold (again) Wed Oct 19, 2016 4:38 am
nino
Having same problem of excessive noise when engine was cold, today I tried to do something with alternator which together with clutch was usual suspect. I always thought that three hard metal to metal point of alternator to engine block resonate too much. I have new bearings in alternator but it didnt help.
Just for test I removed alternator and put three rubber nitrile washers resistant to heat (100 C) and push it back. After bolt tightening I started the cold engine.
Noise partialy dissapeared. Ok I heard the cluth but only with released lever. With engaged lever engine was quiet even on low cold rpms.
Did anyone tried this method? What is experience with rubber washer durability? I used 2 mm thick washer inside diameter 8 mm. When tighten probably squeeze to 1 mm between block and three contacts.
Best regards
2Back to top Go down   Engine noise on cold (again) Empty Re: Engine noise on cold (again) Wed Oct 19, 2016 5:03 am
good work nino
3Back to top Go down   Engine noise on cold (again) Empty Re: Engine noise on cold (again) Wed Oct 19, 2016 12:49 pm
Yeah, good work!
Any chance of a photo?
4Back to top Go down   Engine noise on cold (again) Empty Re: Engine noise on cold (again) Wed Oct 19, 2016 9:12 pm
nino
Its very simple. Three nitrile rubber washer between alternator and engine block on connecting points. Inside diameter of washer 8 mm.
https://i.servimg.com/u/f97/17/38/82/76/washer10.jpg
5Back to top Go down   Engine noise on cold (again) Empty Re: Engine noise on cold (again) Wed Oct 19, 2016 9:21 pm
Thanks!
6Back to top Go down   Engine noise on cold (again) Empty Re: Engine noise on cold (again) Thu Oct 20, 2016 9:09 am
Thanks Nino. This is a good tip.
Engine noise on cold (again) Frog15Engine noise on cold (again) Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
7Back to top Go down   Engine noise on cold (again) Empty Re: Engine noise on cold (again) Thu Oct 20, 2016 4:23 pm
nino
What I can say after yesterday driving around office - caffe - office - lunch - office, mostly on semi cold engine? Old K with 180 000  was noticeable quieter. Few engine runs 4 - 5 - 6 rpm were were somehow more pleasant without usual buzzing.
If anyone try this simple mode, share experience, please.
Best regards
