1 Valve shims Tue Nov 29, 2016 6:22 pm
Bekman
Hi Everyone,
I checked my valve clearance and my intake was a little tight at .13 mm for 3 of the 4 shims. When removed and measured with a vernier caliper all shims were 2.40mm. They were replaced with 2.35mm and the gap is within spec now...
The exhaust which should be .25mm was as follows
#1
.10mm clearance
Shim: 2.65mm
New shim: 2.50mm
#2
Under .04mm clearance
Shim: 2.60 mm
New shim: 2.40mm
#3
.05mm clearance
Shim: 2.65mm
New shim: 2.45mm
#4
.05mm valve clearance
Shim: 2.65mm
New shim: 2.45mm
My questions are
#1 Is my math correct for the new shims I bought?
#2 when I measured the valve clearance after replacing the exhaust valve shims there is virtuall no change and it seems they aren't seated right as some are reading under .04mm clearance.
I ran the starter for a few revolutions with the spark plugs out of the bike to see if that would seat the shims properly (after getting them into correct position by hand) with no change, I also did this by hand with a wrench before trying the starter. I then buttoned up the valve cover and started the bike and warmed it up. It didn't help anything either. I will check again tomorrow when the bike is cool to see if anything has changed. I'm assuming the valve buckets haven't seated to the shims properly even though they are in place. Is this correct and how would I go about fixing this?
James
#1
.10mm clearance
Shim: 2.65mm
New shim: 2.50mm
#2
Shim: 2.60 mm
New shim: 2.40mm
#3
.05mm clearance
Shim: 2.65mm
New shim: 2.45mm
#4
Shim: 2.65mm
New shim: 2.45mm
My questions are
James
Last edited by Bekman on Tue Nov 29, 2016 9:49 pm; edited 1 time in total (Reason for editing : Wrong number)
