1 Throttle body #4 won't balance Thu Sep 01, 2016 9:14 pm
Roland5
I'm attempting to balance the TBs on my 85K100RT with a CarbSync and my number 4 cylinder won't adjust up or down. The adjustment screw moves and works in and out but no adjustments are made in the level of the fluid (vacuum). I'm wondering if I've got it hooked up wrong. I'm removing the vacuum caps from cylinders one through three, and then removing the vacuum hose which comes from the fuel pressure regulator. to the number four vacuum port. I hook the sync to the four TBs and leave the hose from the fuel pressure regulator unattached. All other adjusters/adjustments work. I even switched the sync hoses for three and four and found the same results, no adjusting number four when the screw was adjusted. Haven't replaced the orings on the adjustment screws.
thanks for the assistance.
Roland
Roland
Roland Antumblen
85K100RT - BlacK Beem
Toad Suck, AR
