1 Still Help!! | Ignition intermittent of, intermittent no start Fri Jul 29, 2016 4:58 pm
Chocolate
Hello!
The last days my bikes (K75, 1991, 45tkm, no ABS, garage parked) ignition turns of while I'm riding, not very often. Just for a split second, I realize it while riding, there is no response from the Throttle for a split second. The warning light goes on, I have to use the hand break and rear break to turn the light of again.
I still can go on riding, happend only a few times.
A other issue I had once, was I could not start the bike, I turned the key and nothing happend, no light, no sound from the fuel pump.
After turning the key a few times it worked again and I could start.
I still can ride the bike, it runs except the issue, perfectly.
There are days without any issues.
I assume Cleaning the bike ignition switch could be a solution?!
What are your suggestions?
