2 clutch assembly question Tue Feb 04, 2020 1:41 pm
audibob
Hi Freed,
the clutch operating rod acts directly onto the brass bush in the output shaft.
Use https://www.realoem.com/ to view the aspects of the bike , I find it very useful
Good luck
Bob
Good luck
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
3 Re: Clutch assembly question Tue Feb 04, 2020 1:55 pm
audibob wrote:the clutch operating rod acts directly onto the brass bush in the output shaft.
The clutch pushrod pushes on the center of the clutch diaphragm spring.
4 Re: Clutch assembly question Tue Feb 04, 2020 2:55 pm
Use actual specifications to determine machine clearances rather than murky halftone photos shot at oblique angles.freed wrote: I noticed that center of clutch, there some small part. In haynes manual it seems to be same level with the outer part . . .
5 clutch assembly question Tue Feb 04, 2020 5:12 pm
audibob
Of course , what I should have said is that the end of the clutch rod fits into the brass
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
6 Clutch Wed Feb 05, 2020 3:35 pm
daveyson
One option, if you don't have a suitable slide hammer, you could improvise one.
11/1985 BMW K100RT (late model) Vin. 0090567
~120,000 km
7 Re: Clutch assembly question Thu Feb 06, 2020 3:55 am
freed
I found these parts from local bearing shop: 6x12x12 bonze slide bearing, price was reasonable 1,25€.
Today I am trying to get old one out and sliding new one in.
I am going to make threads to the old and with bolt get it out. Lets see what happens.
8 Re: Clutch assembly question Wed Feb 12, 2020 3:41 am
freed
Worked well, made threads to the old bearing. With spacer and bolt, old one can be pulled away. New in by gently tapping it.freed wrote:I found these parts from local bearing shop: 6x12x12 bonze slide bearing, price was reasonable 1,25€.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Clutch assembly question
Similar topics
