1Back to top Go down   how to test speedo sensor Empty how to test speedo sensor Wed Aug 10, 2016 7:18 am
Ian Drinky
Ian Drinky
  • My speedo has stopped working after removing the rear drive and changing the oil, how do you test the sensor on my 1983 k 100
2Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Wed Aug 10, 2016 7:52 am
Any chance it got pulled a little and got pulled out of the connector into the loom that's rear of the air box? Just follow the wire up....
Happened mine.....
3Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Wed Aug 10, 2016 7:59 am
GTJos
GTJos
Very Happy Hi Ian !
There are several topics on this forum about the issue; just make a search for 'speedo sensor'.
Often it is a loose (or corroded) connector.
Good luck..
how to test speedo sensor Deutch10Ich bin enge Kirchröatsjer jong; adieë wa ?! how to test speedo sensor Deutch10
                                1992  K1100LT 6458188
                                1987 K100LT (RS-fairing) 0170844 + sidecar EML GT2001
                                1986 K100RS 0085647 + sidecar Velorex 562
                                1985  K100RT  0027026
4Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Wed Aug 10, 2016 8:25 am
You can use an electric soldering iron the 50hz gives a signal of 100 pulses per secons which is 61KPH.
Hold the iron element area not the tip very close to the bottom of the sensor when it is out of the rear drive
5Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Wed Aug 10, 2016 10:43 am
RicK G wrote:You can use an electric soldering iron the 50hz gives a signal of 100 pulses per secons which is 61KPH.
This varies by soldering iron. Before I started using Karumba I found that some soldering irons put out a sufficient magnetic field while some do not.
6Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Thu Aug 11, 2016 7:21 am
If you have a good multimeter, switch it to the 'less than one volt AC' setting. Unplug the speedo sensor under the relay box (may be easy to get at under the righthand sidepanel - it's a two-pin connector with a brown and yellow wire) and put the multimeter probes in the socket. Start the bike up and pull it through the gears by hand - if the pickup is behaving itself you'll see the voltage climb from zero to about 0.245 volts AC in top gear at about 3000rpm. Just make sure the rear tyre isn't in contact with the ground! Very Happy
7Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Thu Aug 11, 2016 7:35 am
As Dai says...but the rear brake switch connector is similar and nearby so trace the wire all the way up to the connector.
8Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Thu Aug 11, 2016 11:05 am
The rear brake switch connector have round pins.
The speedo sensor connector have flat pins arranged as a T.
9Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Thu Aug 11, 2016 11:51 am
Inge K. wrote:The rear brake switch connector have round pins.
Thanks Inge. Owe you a lot of beers so you need to start planning a trip over here some time.! They didn't call me Olaf for nothing.
10Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Thu Aug 11, 2016 12:19 pm
Just checked Flights from Rygge to Dublin (return) -  €34 in September.
I will probably spend more on fuel during the weekend run.
There is always a bed for Inge in Dublin (and maybe a few how to test speedo sensor 905546712 )
how to test speedo sensor Ir-log10
 ;BMW; K1200RS Red
11Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Thu Aug 11, 2016 4:21 pm
Inge what are you waiting for now?
We know beer is much cheaper here so I guess at 8 pints you will be at break even.!!!
12Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Fri Aug 12, 2016 1:15 pm
One alternate method is to place a 9V battery between thumb (+) and forefinger (-) of your left hand whilst sticking your tongue into the connector of the speedo sensor. If it does nothing for you it's not your fault.  Wink
13Back to top Go down   how to test speedo sensor Empty Re: how to test speedo sensor Fri Aug 12, 2016 6:53 pm
He's on the forkxxxx already... Twisted Evil
