1 Oil Leak? Fri May 20, 2016 2:19 pm
colly
I just bought a 1983 K100 - it had been off the road for a few years - so I changed the oil, oil filter, fuel, fuel filter, spark plugs, and then eventually it was the fuel pump which got her started. She was running rough so I also cleaned the injectors and fixed and air leak but now she's purring like a kitten. One thing I noticed is a small oil leak. Its right at the bottom at the front, seems to be dripping on the left hand side. I checked and all the bolts are tight. Now When I changed the oil I did not replace any of the rubber - is this essential? Also, when I put the new oil filter in I just tightened it as much as I could by hand - I don't think there was space enough to get a too in there. Is that ok or am I wrong? What should I do to fix this?
