1 how to test speedo sensor Wed Aug 10, 2016 7:18 am
Ian Drinky
- My speedo has stopped working after removing the rear drive and changing the oil, how do you test the sensor on my 1983 k 100
RicK G wrote:You can use an electric soldering iron the 50hz gives a signal of 100 pulses per secons which is 61KPH.
Hold the iron element area not the tip very close to the bottom of the sensor when it is out of the rear drive
Inge K. wrote:The rear brake switch connector have round pins.
The speedo sensor connector have flat pins arranged as a T.
92KK 84WW Olaf wrote:Inge K. wrote:The rear brake switch connector have round pins.
Thanks Inge. Owe you a lot of beers so you need to start planning a trip over here some time.! They didn't call me Olaf for nothing.
Similar topics
