1Back to top Go down   Driveshafts Empty Driveshafts Sun May 16, 2010 2:54 am
robinm
robinm
just noticed that Motobins are doing new driveshafts, both 16 spline and 20 splines at a real good price. if you are looking for a new one then definitely check them out. Priced at 95 pounds, hard to get a good S/H one for that.
2Back to top Go down   Driveshafts Empty Re: Driveshafts Mon May 17, 2010 6:15 am
green cat
green cat
Driveshafts Icon_cheers good news!!!
[img]Driveshafts 3cc2228804714fdc8e93fe1f84a93706[/img][img]Driveshafts K1100l10
3Back to top Go down   Driveshafts Empty Re: Driveshafts Thu May 27, 2010 3:48 am
robinm
robinm
Bit the bullet and ordered a new one last week. It arrived today
Driveshafts Web_dr11
4Back to top Go down   Driveshafts Empty Re: Driveshafts Thu May 27, 2010 6:49 am
This seems to be an original shaft and the price is very good.
Is it a brand new one or a reconditioned one?
Motobin is selling the splines and may recondition their shafts. scratch
Driveshafts Frog15Driveshafts Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
5Back to top Go down   Driveshafts Empty Re: Driveshafts Thu May 27, 2010 1:59 pm
robinm
robinm
Brand new, motobins are no longer reconditioning shafts, they still sell the splines, I have another shaft at the engineers now getting a new spline welded on, but they no longer supply exchange shafts like they used too.
6Back to top Go down   Driveshafts Empty Re: Driveshafts Fri May 28, 2010 11:24 am
Avenger GT
Avenger GT
Checked their website, price seems to be for 20 spline only.
7Back to top Go down   Driveshafts Empty Re: Driveshafts Sat May 29, 2010 12:34 am
robinm
robinm
Yes, I saw that, my first post was incorrect, it is only the 20 spline ones at a good price.
8Back to top Go down   Driveshafts Empty Re: Driveshafts Sat May 29, 2010 10:04 pm
robinm
robinm
OK I fitted the new driveshaft today. There must have been a modification to the specs of the drive shafts some time in the past. The new drive shaft is actually larger at the universal joint end and will not slip up the end of the swing arm. The opening in the end of the swing arm is 55mm and the diameter of the drive shaft universal flange is 55.25mm. A few minutes work with a coarse file on the swing arm and it fits. If you look at the photo above you can see where the driveshaft steps up in diameter by the UJ, the original one does not. But it is not a big job to open up the end of the swing arm .25mm (only in 4 places required)
9Back to top Go down   Driveshafts Empty Re: Driveshafts Fri Jun 04, 2010 6:27 pm
robinm
robinm
After fitting driveshaft in said manner I emailed Motobins about it, I also mentioned that the spline was as not as tight fitting as the replacement spline I got at the same time. This is their reply.
Sorry this is a genuine BMW item and this is just how they come now to fit
them you need to remove the swing arm and drop them in from the gearbox end.
As for the spline not being as tight as the replacement spline this is
because we have the replacement splines made very slightly oversize as they
are usually being fitted to final drives that have a very small amount of
wear.
Regards from Damien
Moto-Bins Online
Due to the fact that the repair spline is slightly oversize (undersize) I would suggest that it would be a better option than a new driveshaft, unless the spline on the final drive is 100%. .
Robin
