1 K75 intermittent stalling Tue Jul 12, 2016 5:35 am
PasiVee
Hi all,greetings from Finland!
a K75 c -87 (110K kms) began behaving oddly right after I took it out last May. Bike started immediately for a while until I switched her off. After that, no go. Starter motor turned but it sounded like something was wrong with the sprag clutch. Motor won´t start. Battery was sound, fully loaded. Decided to overhaul both starter motor and alternator. Checked also plugs and changed two gasoline hoses (tank to rail, return). Opened all the under tank connectors ( not the handlebar switches connectors) and used Deoxit like stuff. Overhauled starter switch (thanks Don Eilenberger)but not the start button. Looked also into the relays box, nothing loose nor corroded, no smell. Cleaned the tank inside, there was some black stuff, not plenty of it. Changed fresh gasoline.
And she started and run perfectly. Taking her to the road after 2 kms riding motor suddenly stalled just like if I had used the kill switch which I did not. All instrument lights stayed on, and I could jump start it immediately, not even stopping first.
Same has happened after that two- three times. Just dying suddenly and (jump ) starting immediately.
Any idea where to look next? I think next I´ll let her run for one hour at our summer cottage to see if it´ll die or not, then try again on the road. If it happens only when riding, would that indicate loose connection?
Thanks for replying and excuse my english
Pasi Viitanen
Pasi Viitanen
